Can anyone solve my mystery clunk
So @KATOOM wants to know more about my mystery clunk.
When unloaded I have a pretty nasty clunk/crash that can be felt in the floor.  Steering doesn't seem to be effected though.   It is directly related to when you unload the front suspesnion.
From the drivers side it feels like it is coming from the passenger side, from the passenger side it doesn't feel as bad.
Before we get into what I have replaced we need to look at the history of my truck, the PO must have broke the front axle as i have a 1994 d60 under the front rather than the 2000 that I was supposed to have on the truck,
Things I have replace that made no difference,
- ball joints, all of them
- steering assembly, 2x
- control arms 2x, upper and lower with new hardware and welding the caster adjuster in place, now have adjustable control arms due to that.
- control arm bushings 3x
- body mounts,
- sway bar mounts and bushings
- sway bar end links front and back.
- wheel bearings
- shocks 2x
- track bar 3x
Things I am wondering about still,
Motor mounts, doesn't happen when I get on the skinny pedal though.
ovaled out body mounts for the control arms.
So who has the magic answer to my clunk?  I rightly dont care anymore. after 4 years of the clunk I just couldn't be bothered to fix it lol.
Edited by Me78569
  • Replies 71
  • Views 14k
  • Buzzinhalfdozen
    Buzzinhalfdozen
    Based on what you've checked and replaced I wouldn't think it's a driveline/suspension issue. You should start looking at weird things like: Loose or cracked crossmembers.    Broken spo
  • Damn it ME now I am starting to hear a clunk under my passenger side now. Mostly bumping around on the job. Not so much on the road yet. Everything on my front has got little over 100k on it so maybe
  • Well to add another chapter, I did go ahead and replace ball joints again.     My uppers did have a touch of play in them. I wouldn't consider them bad, but hte alighnment shop did.
well I snugged up the track bar mount, no go.  New set of wheel bearing as the timkens gave up the ghost after ~80,000
I am starting to think that my clunk might be engine mount / trans mount related.
2x ball joints
2x wheel bearings
3x track bar
2x upper and lower control arms with new hardware, welded camber adjusters
1x swab links and mounts
2x shocks
3x pitman arm to kuckles steering linkages
1x all u joints
What gets me is the steering wheel does not move / vibrate / jump at all but your butt / feet / ears hear and feel the truck "side step"
Edited by Me78569
seems to have migrated to both now, but orginally up front.
cab mounts? When I replaced mine they were all different heights from getting squished over time
Could be.  I wonder if the can is banging on the frame.....
Edited by Me78569
The fuel sloshing in the tank made a wierd noise and feeling sort of a clunk on every 2nd gen i had over time. Not sure why but it would be totally annoying in certain driving conditions.
:popcorn:
