Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 362.4k
  • Quadzilla Power
    Quadzilla Power
Np once you get your starting point % figured out let us know and we can help build a tune from there
6 hours ago, thatblackvptruck said:
Ok thanks for the help
were you able to find a good starting % for your setup?
When towing do you still want to stay around 17-21 degrees of timing at hwy?
I know you don't want any cruise timing adv.
That depends on your rpm.  What RPM are you towing at?
2k revs on a tow tune I would do ~17*
2.5k revs on a tow tune I would do ~21*
Might take some time on Lvl 0 and watch how OEM timing works.  Might help you figure out what will work best for you.
 Hey guys,
Im seeking help in regards to my wiretap tunes not being "smooth" it almost like my wiretap comes on and off when in lvls 3-5. My canbus tun is very smooth throughout the rpm range. When in the upper lvls you can hear the exhaust note ramp up and down when the wiretap is on and off, even when WOT. I'm using Me78569 stock injector tune w/ boost scaling at 20. I have stock injectors and turbo.
I thought my V2 Tuning may have just needed an update so i did that today and it still behaves the same way. I have attached a data log file below.
Fun
Power Levels: 6
RPM Limit: 3400
Maximum Valet Mode Power: 25%
Maximum Fuel Stretch: 2200
TPS Pump Maximum: 100%
TPS Pump Minimum: 0%
Minimum Pump Tap Fuel Precantage: 50%
Boost Scaling: 20
Max Load Timing Offset: 3
Timing Reduct Scaling: 100%
Light Throttle Timing Adv: 1
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Max: 26
PSI %: 101
PSI %: 103
PSI %: 105
PSI %: 107
PSI %: 110
PSI %: 113
PSI %: 116
PSI %: 119
PSI %: 122
PSI %: 125
10 PSI %: 128
11 PSI %: 131
12 PSI %: 134
13 PSI %: 137
14 PSI %: 140
15 PSI %: 143
16 PSI %: 146
18 PSI %: 149
20 PSI %: 150
22 PSI %: 150
24 PSI %: 150
26 PSI %: 150
28 PSI %: 150
30 PSI %: 150
iQuad-2017-03-25-01.32.141687763203.csv
Edited by Me78569
Verify your wiretap is connected well.
Next drop your min pump tap fueling %.   Having min pump psi at 0 psi and min pump fuel % at %50 means that you are getting a min of 50 wiretap if you leave the line at high throttle.
Try min pump tap %15 and pump low boost scale of 5 psi
@Me78569, @TFaoro, or anyone else who may be able to help: I just switched to a SO vp, and I have found that my daily driving tune needs to be tweaked to fit the new pump.  Everything was going fine until tonight, when the truck started acting up.  When revving, at the 1500 rpm point, the truck starts surging and popping, with plenty of white smoke.  I know this was a timing problem addressed before, so I am surprised to see it pop back up.  I am on the latest version of the Hard Fuel tune.  When the Quad is completely disconnected, the truck behaves normally again, so I'm hoping the issue is in my tuning.  Below I will post both my old HO pump tune and the new SO pump tune, in hopes someone can spot what I am missing.
First, the old HO pump tune:
Power Levels: 11
Timing
Fuel Load Timing: 1*
Low PSI Timing Reduct: 2*
Light Throttle Timing Adv: 2
Timing vs rpm
1500: 15*
2000: 18*
2500: 22*
3000: 24*
Timing Max: 25*
Wiretap
Pump Stretch: 1800 us
TPS Pump max: 100%
TPS Pump Min: 15%
Minimum Pump Tap Fueling Percentage: 0%
Pump Low Boost Scale PSI: 2 psi
Boost Scaling: 25 psi
RPM Limit: 3300
Power Reduction: 70%
0 PSI %: 83
1 PSI %: 83
2 PSI %: 84
3 PSI %: 85
4 PSI %: 86
5 PSI %: 87
6 PSI %: 88
7 PSI %: 90
8 PSI %: 92
9 PSI %: 95
10 PSI %: 97
11 PSI %: 99
12 PSI %: 101
13 PSI %: 103
14 PSI %: 105
15 PSI %: 109
16 PSI %: 111
18 PSI %: 113
20 PSI %: 115
22 PSI %: 117
24 PSI %: 119
26 PSI %: 121
28 PSI %: 123
30 PSI %: 124
And now for the new SO pump tune:
Power Levels: 11
Timing
Light Throttle Timing Adv: 2.5
Timing vs rpm
1500: 15*
2000: 18*
2500: 22*
3000: 24*
Timing Max: 25*
Wiretap
TPS Pump max: 100%
TPS Pump Min: 15%
RPM Limit: 3300
0 PSI %: 86
1 PSI %: 87
2 PSI %: 88
3 PSI %: 89
4 PSI %: 90
5 PSI %: 91
6 PSI %: 92
7 PSI %: 93
8 PSI %: 94
9 PSI %: 95
10 PSI %: 97
11 PSI %: 99
12 PSI %: 101
13 PSI %: 103
14 PSI %: 105
15 PSI %: 109
16 PSI %: 111
18 PSI %: 113
20 PSI %: 115
22 PSI %: 117
24 PSI %: 119
26 PSI %: 121
28 PSI %: 123
30 PSI %: 124
So the new tune is basically the same as the old tune, with different CANBus settings and a 3* timing advance instead of 2*.  Any thoughts on why the truck would start missing? This tune worked fine for a few hours and then the truck started to act up.
Edited by Me78569
Datalog datalog datalog.   In my experience white smoke and popping is due to too little timing.
Does this happen on the road?  Driving easy? Hard?
You can try to mirror OEM timing
1500 13*
2000 14*
2500 18*
3000 24*
3500 26*
This issue started after driving on a very long washboarded gravel road. At first it would pop in gear and free revving, but towards the end of the road when I unplugged it, it would pop once when in gear, not at all when it was slowly free revved, and really badly when it was quickly free revved. I will give OEM style timing a try and will do my best to get a data log of it
My thought process on this issue
1. it was working without any changes ( so what changed?)
2. why 1500 rpm?  ( oem timing is the low limit and quad 1500 setting is upper limit)  whats happening at that point?
A data log would be very helpful so we can spot whats up.
I would also drive around on lvl0 only for a bit and see if it happens still after a few days.  Drive it HARD.  At 1500rpm I would expect thew low limit setting of 8* to be enough to make it run without popping and smoking so I am not sure what is causing white smoke at such a low rpm.
Regardless I think I am headed up to denver friday to help a guy out, maybe we can meet up and see whats going on.
Well there's no exciting data log to look at because the truck didn't do it today. Quadzilla plugged back in, same SO tune as above, and on level 3. So using Roadkill logic, that means it's fixed, right??
Just kidding, I'll still keep an eye on it
Trevor as we chatted about I owuld just keep and eye on things
The hard limits in place on the Quad are not low enough to cause white smoke at that low of an RPM.  Limits are 8* to 30* so at 1500 rpm you would need less than 8* to cause white smoke.
Could be a VP issue, I looked at a 2nd gen with a similar miss at 2000 rpms
Is there a link to the downloads for the old tunes? I want to flash the old tune and see if I still have the same issue. I had the ADR2_COMP before I flashed the V2. Don't want to go through the hassle of shipping it to quadzilla.
Just watched your video.
Is your tc unlocked during that?  I have to say I can't even begin to guess what is causing it.  It looks like your tc is unlocking or something.
Gonna think on it.
