- Replies 22
- Views 5.3k
Mopar1973Man 6 posts
JAG1 6 posts
KATOOM 5 posts
dripley 2 posts
Shut down doesn't matter. Like I can lay my laptop in my pickup turned off at 160*F without harm. Now pull it out after soaking in the heat turn it on and it will work just fine. Most all electronic d
Thanks to you all for the information. I only use the fan after the engine is running going down the highway, so my questions are only educational, and interest. After a good cup of coffee
My fuel system is laying on my carport floor right now. Before I re-install it I was wondering if there was anything else I might want to upgrade to make it better. Playing around on internet found a posting about cooling the VP with fans or fuel coolers. Mostly 3 or 4 people posting between 2005-2014. Seams like good idea in theory. But if idea is really good I would think there would be kits available or more info about them. I read somewhere (Blue chip diesel I think) that the most heat the VP is exposed to is the first 20 min after shutting off motor thru heat transfer.
Any ideas about lowering temps in VP? Anybody have a ideas about cooling your VP? Is it possible to move your elec from VP to a cooler place, maybe using wires?
(if interested...46 pages, basically dozen people recording their operating temps of VP and fuel)
https://www.turbodieselregister.com/threads/135952-Modifying-fuel-system-so-temperature-input-to-VP44-80*-100*-your-inputs
Edited by 015point9
spelling
