- Replies 44
- Views 10.9k
BigPimpin 13 posts
dripley 8 posts
Me78569 8 posts
Mopar1973Man 5 posts
When you installed your Raptor did you bypass or remove the in tank pump? I have a mechanical FP gauge and install the line for it after my filters so if they start to clog I can see it in lower press
They have a steel nut embedded in the plastic... It'll probably plow through the PSG before stripping any threads. That said, if a user doesn't follow instructions that's a personal problem
Test for boost leaks as a first step.
Hello everyone. I'm having some issues with what I'm thinking might be a boost leak, but I'm not really sure.
I have an 02 5-speed 3500 4x4 with a Raptor 95 and 75hp industrial injection injectors. It also has a bhaf, and a magnaflow 4" exhaust. I had a smarty on it but installed my Quadzilla Adrenaline today, and I noticed that I'm only getting up to 12 psi of boost.
Now I didn't have any gauges before the Quad, so I don't know if those are the numbers I've always been getting, but I do know that I don't seem to be making any more power from Level 0 through Level 7 than I was with the Smarty. I haven't tried anything higher than 7 because it was raining.
So I guess my real question is how much boost should I be getting, and when? In second and third gears it gets up to about 7 psi. It only really gets up to about 12 in fourth at about 2000rpm. I'm going to play with it again tomorrow, but it's been bugging me all day and I thought I'd ask about it in here.
Sorry if this post was all over the place. I'm just kind of freaking out about not getting the power I was expecting from this thing.
