My addiction
So this is the truck that started my addiction. This is about what it looked like when I brought it home in 2010. It has had a few different turbo, injector and pump setups. I'll just give a quick run down of what they were and what the current is.
First setup (past stock) was a set of cpp 7x.010s, he351cw, tst pm3/diablo power puck/smarty, built auto, and ad II 165.
Next notable setup was a bit of a step up. s467.7, Infinite performance 6x.013s, tst comp/ts mvp, common rail cylinder head, same built auto and lift pump. All this time was on the original injection pump which I did not realize until I ppumped.
The day after the dyno I decided to ppump to meet my further goals. Only things I changed was the injection pump and cylinder head (common rail head does not have the clearance required for a ppump). Single best modification I have ever done to the truck. Less smoke and more power. I ran 3 different turbo chargers with the first 180hp pump. S467.7, S475 and finally a S472. At which point I decided I needed compounds. Dyno sheet is for the initial setup. A 180hp pump with 5ks & 024 dvs, same 6x.013s, same trans and same lift pump. With a bit of nitrous involved.
received_m_mid_1402584990873_ef0d5fa9465
And that brings us to the fun one. The compounds. The secondary (manifold) charger is a 66/68 with a .91 t4 housing. The primary is an S4T 86/110 with a 1.15 t6 housing. At this point I did purchase another ppump and sent it to Farrell Diesel to be benched. Transmission has been updated to a monster pump mike bolt together torque converter, larger input shaft and one of mikes outputs. I also stepped up to larger injector from Infinite. 6x.018s. It is a bit rowdy now lol.
  • Replies 147
  • Views 28.6k
    Thank you for that bit of information.
  • The last trans. builder wanted to upgrade the output for obvious reasons. I never broke it. The truck with vp on it went 7s in the 1/8th on a stock output.   A vp truck will not outflow the
  • Just some old steel wagon wheels and cooper at/3's (junk)     Yea a whole 2hp difference LOL
I haven't seen any that actually polish up well. A buddy had one done and it is dull at best.
2 hours ago, CSM said:
Full polish, red letters.
No No No. Black with shiny letters!
  • 4 months later...
Forward and reverse.
@Me78569 trans has to be in to start it. Converter and all.
Uhhhh you sure? I started mine without the trans....Doesn't the flex plate have the teeth on it for the starter?
100% positive lol. My converter is not like the rest ;)
Oh well aren't you just special :shifty:
So are you going to blow a rod through the side of the block this weekend??
It made 870 last time on a dyno.....like 3 years ago LOL. It will make 869 just to irk me.
:lmao: or when the primary lights it'll blow the trans apart!
:thud:
:surrender:
Well it hasn't done it yet on the street! I did rotate tires so to get the ones with more tread on the back :lmao:
Edited by jlbayes
:thumbup2:  Are they going to be able to keep traction while on the dyno? That's going to be a pain if they can't pull it down hard enough.
Supposedly yes. Though I am not hoping for anything great based on some other higher powered trucks that had been on this dyno. Lotsa complaints it is low.
Take it to the track... you'll know better there anyway.
real men dyno then make excuses as to why the numbers are low
