Looking for Staff Members
Need some help here!  2001 Dodge Ram 3500 5.9 cummins diesel.  Air Dog Original,fuel sump kit, New VP44, A&E Air Box Kit. Smarty S03 stacked with Edge Juice W/Att.  All of a sudden the truck start to like basically cut off all horsepower if i stand on it, so i have to back out of it and it takes off again.  I took smarty off and edge juice to see what the truck does.  With all programmers off the truck it has basically NO Power ever, feelings like im pulling a train!  I took truck to dealership they flashed both ecm,pcm back to stock and uploaded all updates including set my 35 in tire size.  Truck Did have a little bit of power but not really driveable.  Have code po501 and thats it besides po1693.  Please help send me in a direction that will solve this issue.
Edited by CSM
  • Replies 99
  • Views 13.9k
  • Firstly can you fill out your sig so we know what you have on your truck?  I can't rememeber are you still running a stock turbo??? ( please tell you aren't)   Next you really should unstack
  • Hard to know what you know by " no power" a stock 2nd gen truck is a real dog.  235 hp trying to pull 7000#.     Do you have 150 injectors as well? or where you asking in regards to upgradin
  • I just put the Fuel Gage sending unit on 5 minutes ago, I'm going to drive it now. It sits at 19 idle
My understanding is the OFV, ove flow valve, has a small by pass in it. If  either bolt on the head or the tee is letting air in it will drain the fuels system. How long it takes depends on how much air is being allowed in. The fuel system hold no pressure once the engine is shut. I had hard starts for a while and replacing the tee grommets and the washers on the head bolt solved my issue.
Edited by dripley
24 minutes ago, Me78569 said:
whats ofv?
Over Flow Valve. In the return line at the vp.
Truck went into limp mode for a few moments yesterday, and throwing code p0237. Tried Cleaning it but light keeps coming back On.  Be nice if that also fixes the low power issue
Map sensor code is gone. still scratching my head on the cutting out issue.  OverFlow Valves will be here Thursday and if that don't fix it? VP$$
On 3/17/2017 at 8:10 AM, Mopar1973Man said:
I wouldn't suggest plugging the return line. Take a risk of blowing the front seal out without a return path.
Heat is one factor but I'm still waiting to see summer heat. So far I've not seen anything temperature wise that would even be stress full to electronics yet.
For some reason I can't just reply to thread, I think I'm quoting. But anyway oil pressure sensor shears same  close 5volt loop. Change oil pressure sensor just in case. :2cents: probably won't help but ....
out of the blue 237 code and the truck in a limp mode for moment.  Whats on your mind for ideas I can check?
I can do that first thing in the Morning. Link didn't open but I found the procedure.  thank You
More than one sensor shares that 5v reference. Same with the ground.
Did Map sensor code test.  Checkout to be bad Map Sensor.  Code has been gone for 2 days now.  I replace the overflow return fuel valve. Again there was Not even a drop of fuel in the return line.  With that finding i'm going to have to go back to my original thought and replace the New VP44 due to fuel pressure going down to 5psi couple times.
whoa whoa!
Just because fuel pressures dropped below 5psi doesn't mean your VP44 is toast! It's definitely not good for it, but it's not an instant killer. Is the pump under warranty? If not, I'd just ride out this pump until you have a VP44 death code. At the very least walk through Blue Chip's procedures for checking if your VP44 is toast.
A dry overflow return valve to me just indicates that the valve was just bad.
I checked both new and old overflow valves.  They both are Good.  I'll look into blue chips procedures and vp is not under warranty because I tapped the pump wire
Yea I mean, I'd go through every check to verify my VP was bad before I started shelling out the money for a new one. Still not getting any VP codes? I know its possible for the VP to fail with no codes but from my understanding is it's fairly rare. Blue Chips procedures should give a pretty definitive answer as to whether the pump is bad or not. Let us know what you find!
I will let you know by tomorrow.  The truck has long crank time again in the morning and you have to back out of the pedal at full throttle because it slows the truck down.  Same symptoms my last vp had but it had a p01688.   I have no codes except 602 from Smarty stacked with Edge
