Quadzilla Adrenaline Economy and MPG
Since @Me78569 and company have the tuning thread for performance side. I'm going to start the ecomony and MPG thread for the Quadzilla Adrenaline. I'll be posting up my MPG logs and all data I can provide of what I've got going on. I've been keeping hand math logs of all fuel purchased as well as my tablet running OBDII link LX and data logging from that direction too. I'll share my tunes and settings as well.
QUADZILLA TUNES CURRENTLY LOADED (Check back often file is updated at random times)
Quadzilla Ardrenaline.xlsx
  • Replies 431
  • Views 159.5k
    Finally!!! Yeah!   Broke 21.06 MPG. Finally got the tuning figured out. 297 miles and filled up with 14.096 gallons giving me 21.06 MPG. This is still with winterized #2 diesel and winter co
    I've learned a lot so far.    Light Throttle Load Limit (Percent) - Mopar1973Man Suggested Setting 25%   This value should be built around the 65 MPH speed on flat ground. That is
    Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I
And officially averaging 23.82 MPG in south florida,
Highway tune
Cruise timing 2*
Canbus fuel starting % 100% up to 10PSI
Average cruise timing = 18.50 - 19.50* depending on speed. Typically cruising at 70 MPH
Also, only running PL2 on these trips and cruising flat turn pike or I-75 at 4psi boost
truck stop to truck stop on I-75, over two weeks. One day I drove 48 Miles to work on 1.94 Gallons of fuel.
But it was 10PM and I didn't have to slow down at all.
The big injectors don't like a ton of timing if you pull fuel %. my smokeless tune for city driving is crappy on mileage because the starting canbus % is 83% and it dogs hard on the Load and TPS
Pretty much I am driving 600 - 650 miles between 31 gallon fill ups on the regular, as long as I keep my foot out of it.
So at 55mph my truck bounces around at 1390-1400rpm. That's why cruise won't lock in. Makes sense on why I was able to with my old version when it was mph based and not just rpm.
Edited by SquatchHunter
Extra wordss
1 hour ago, Me78569 said:
Well congrats on the mileage
Yeah if only I could get that all the time! South florida has no hills so its a little easier I guess. @Me78569 what are you getting on the highway? I bet the VGT turbo helps.
65 I can hit 25mpg no trouble....my truck isn't safe at 75 so I don't bother driving that fast lolol.  the vgt actually doesn't help much from what I have found.  I can set her wide open or down on my race tune and MPG is pretty much the same.
Edited by Me78569
4 minutes ago, Me78569 said:
65 I can hit 25mpg + no trouble....my truck isn't safe at 75 so I don't bother driving that fast lolol.  the vgt actually doesn't help much from what I have found.  I can set her wide open or down on my race tune and MPG is pretty much the same.
Nice, and you don't have to deal with the dually crap!
3 hours ago, Me78569 said:
...... more info?
I pulled my Vulcan injectors out and installed my stock injectors back in. I just about ate the grid heater gaskets so I made a run to McCall, ID to get the new gasket. Even after hard pulls (what you would expect with stock) it was idling fine and smooth in town. EGT's a bit higher than the +50 HP injectors. Timing rattle is nearly gone like I need to crank up more timing. Runs very smooth absolutely smoke free. Now last trip down to Bosie, ID when I fired up in the morning the exhuast was just lightly smoking white and smelled of fuel. Another clue something was wrong. I basically gave in swap back to stock and problems are gone.
My problem is I don't really want to play the pop test game much and end back up pulling them all over again in a few months having to deal with another misfire or injector issue. Made a few phone calls to see what I've got for options for injectors. @dieselautopower is trying to set me up with injectors... Might be closer to +90 HP SAC's... :whistle:
So when are you getting a pop testing device and start popping and rebuilding members injectors?
Not happening... I wish I could... Right now with all the driving back and forth for MoparMom is keeping the budget extremely tight. I'm not capable to work any jobs really because of the time factor. Being my travel days are 12 hour days. So my off days I end up doing maintenance on the truck and keeping it in good repair. So like today was swapping out injectors and shopping for replacement injectors.
FEB. fuel logs...
So it doesn't give me much for buying tools...
I ran those exact injectors for a while. They run very well, but with the tuner up things got VERY hot on the stock turbo. Mid 1600's or so if you keep in it. Quad should be able to keep fuel tied down though. I'd expect mileage to stay up without a problem.
SUGGESTED http://dieselautopower.com/diesel-auto-power-75hp-performance-injectors-7x0-0085-sac-vp7x85sac75/
http://dieselautopower.com/diesel-auto-power-50hp-performance-injectors-7x0-008-vco-vp7x8vco/
So @dieselautopower is suggesting the first link for injectors. I'm kind of building this in mind with a HX35/40 turbo being installed too. This way I get a bit more bang for the buck power wise, keep the exhaust brake, and also keep the MPG tune thought in mind.
Bigger than stock tires?
I really don't want to push timing that hard that low,  I tried to pick the best range for cruise timing that wouldn't be in a lugged state.
I'm going to upgrade to CSMs turbo he sent to me. That happened to be HX35/40 turbo just needs bearing kit. Also I'm not the type to run wide open very long, maybe passing other vehicles. Towards the end my 60s were slamming against the 1300 limit I've set. I've got to admit the stock injectors are smooth but power is reduced quite a bit now. Dropped me From my 19 to 20 MPG to barely 16 to 17 uncalibrated.
Yeah, I have 33s on it. No problem. Better to just drive a little faster than strain the truck.
