Quadzilla Adrenaline Economy and MPG
Since @Me78569 and company have the tuning thread for performance side. I'm going to start the ecomony and MPG thread for the Quadzilla Adrenaline. I'll be posting up my MPG logs and all data I can provide of what I've got going on. I've been keeping hand math logs of all fuel purchased as well as my tablet running OBDII link LX and data logging from that direction too. I'll share my tunes and settings as well.
QUADZILLA TUNES CURRENTLY LOADED (Check back often file is updated at random times)
Quadzilla Ardrenaline.xlsx
  • Replies 431
  • Views 155k
    Finally!!! Yeah!   Broke 21.06 MPG. Finally got the tuning figured out. 297 miles and filled up with 14.096 gallons giving me 21.06 MPG. This is still with winterized #2 diesel and winter co
    I've learned a lot so far.    Light Throttle Load Limit (Percent) - Mopar1973Man Suggested Setting 25%   This value should be built around the 65 MPH speed on flat ground. That is
    Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I
Guys,
I am so far behind right now. I have found where the app updates are in the download section. However, where/how do we download the tunes that are posted? Do we need to plug the Quad into the compute like when we are updating it? Also, how can we post our tunes? Is there an export feature that I have missed in my absence? I am currently using a Samsung galaxy tab for the guages, do i download the tunes from the website onto that in the Quad app? Any help will be greatly appreciated. Going on a road trip today and would like to do some testing.
Thank you,
JD
The import / export app is still in beta and is not publicly released yet.  It is coming very soon.
I cant seem to find my way back to the logs of the tunes. The ones with the full data builds. I think I have gotten past my iQuad issues. Can you link me back to it?
Here's the 4k base tune
Here is the thread with our tune variables
Your tune settings will be a bit different since you are 4k.  added stretch and rpm limit, 2 more timing variables.
I have good friends in Palo Iowa and Vinton haha.  You might have to some time.
I'm Minutes away from those places, just let me know and Ive got the first couple rounds.
@Me78569 Hey man, The tune repository is a great idea! can you give me a quick run down on the latest flash? any new features since the March Flash? Sorry Ive been off a while got divorced and all.
I can't remember that far back.
Honestly the only real big change is that "cruise timing" is now "light throttle timing"  it works based on load.  If load is under X% ( whatever that tuning variable is) then you get your base map, plus light throttle timing * load / 100   It has netted me a good bit more city mpg and much more reliable cruising mpg when in situation other than flat ground.
other than that some basic bug fixes that were hard to even consider bugs.
can you post the link to the latest flash? it looks like some things have moved around. Also, it would be nice to track revisions and changes just saying. lol Thanks bro
Nevermind I found it, I just hope the .apk is updated lol
Is there a link to the latest apk with import/export ability? I can't seem to find it. Thanks!
  • 4 months later...
Currently I'm running level 3 being I'm not wire tapped yet. I'm also running +75 HP injectors (7 x 0 0085). Also no longer running the stock turbo (54/60/12) I'm running HX35/40 (60/60/12). Soon I'll tap the pump and go back to level 7. I'm currently producing a look alike tune that mimics Edge Comp. I'm close.
What level are you seeing your best mpg at? I’ve tried level 2-6 and I still can’t get a very good mpg. I’m currently getting 14-15. I’ve based my tune off of your old tune that you were getting 20mpg out of.
level 2 + should all give nearly the same mpg as timing is what makes mpg good or bad,  all levels above 2 use the same timing.
Crusing at 75
Cruising at 65
Here is my current tune that I’m running. Note my mpg wasn’t set when these pics were taken so it isn’t accurate C6C61E82-8229-4300-968B-9BB27A8D112E.jpeg.caa4639b67bbd05231d216da3052b1e6.jpegD68A0918-9906-4324-A798-B215768185AB.jpeg.2f3e81b3b4d8f0d0c6c2b403d4626967.jpeg9BAB62FB-9162-4781-89A6-28F7A631FBFC.png.bea8a3cdb9d4d5892245009a339c1dbd.png
so your light throttle limit is set to 30%, so you wont be getting high timing unless engine load is below that %30 mark.  In both of those shots it was above that.
You should be wanting ~23* of timing at 75.
change your light throttlr timing limit to %40 and see what happens. I am betting mpg will jump signicantly.
I am guessing you have stock injectors?
Yup stock injectors. I read earlier somewhere on the page that going over 30% was not recommended so I’ve just been setting it to 30%.
