Since @Me78569 and company have the tuning thread for performance side. I'm going to start the ecomony and MPG thread for the Quadzilla Adrenaline. I'll be posting up my MPG logs and all data I can provide of what I've got going on. I've been keeping hand math logs of all fuel purchased as well as my tablet running OBDII link LX and data logging from that direction too. I'll share my tunes and settings as well.
QUADZILLA TUNES CURRENTLY LOADED (Check back often file is updated at random times)
Quadzilla Ardrenaline.xlsx
  • Replies 431
  • Views 139.4k
    Finally!!! Yeah!   Broke 21.06 MPG. Finally got the tuning figured out. 297 miles and filled up with 14.096 gallons giving me 21.06 MPG. This is still with winterized #2 diesel and winter co
    I've learned a lot so far.    Light Throttle Load Limit (Percent) - Mopar1973Man Suggested Setting 25%   This value should be built around the 65 MPH speed on flat ground. That is
    Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I
18 mpg cruising at 80 mph with some stop & go on the 6x0.013's. :)
I think @trreed‘s injectors are a teensy-weensy bit bigger then yours though Mike. Makes sense for you to pull those numbers.
Plus compound turbos... Way different setup. Also, I'm not driving any roads that allow for 80 MPH anymore.
340666 - 340368 = 298 / 13.948 = 21.36 MPG
I was hoping for more. I guess ill have to get busy putting effort into this beast. I need to at least be mid 20s which to me is 24 to 26 MPG consistently. I'm at least above average for most here on the website.
Just doing some math 300 miles ÷ 12 gallons is 25 MPG. I was at 13.9 gallons at 298 miles. So I've got to shave off 2 gallons of consumption in 300 miles.
Ill get there. Back to checking drag items like brakes, parking brakes, etc. Valve lash check again and go tight side again on the 0.008 and 0.018 again. Injectors with higher pop pressure. I'm going to do it.
I have 4.10 gears I wish it was 3.73… with my 275/85/17s I could get some decent OD rpms on the highway :-)
Hey what does DAP charge to up the pop pressure? Wonder if it's worth sending them back for it
You are close enough with your tire combo... 3.67:1  to the ground.
No i wanted to start at 3.73. I'm jealous that the new trucks can be under 2000 RPM at 75 or 85 miles an hour, iirc. I think I'm at 68 mph at 2000 RPM
Edited by beren
41 minutes ago, Silverdodge said:
At 75 I'm at 1900 ish 35s and 355s but it creates lugging
That's because your final ratio to the ground is roughly 3.19:1 which is way too tall of a gear ratio.
Yep but empty it's ok loaded highway it's ok loaded back road I shift out of od
Fuel log...
340955 - 340666 = 289 ÷ 12.935 = 22.34 MPG.
Price: 3.299
I'm happy to report the MPG display is very close to correct about 0.2 gallons off. This is 0.98 MPG gain over last tank. Only change to the tune is dropped 1 degree of cruise timing.
Catch me if you can...
I've got to apologize for not posting MPG logs...
340951 - 340666 = 285 ÷ 12.935 = 22.03 MPG (5/1/18)
341245 - 340955 = 290 ÷ 13.726 = 21.12 MPG (5/3/18)
341541 - 341245 = 296 ÷ 14.563 = 20.32 MPG (5/5/18) Trailer towing (~30 miles)
341787 - 341541 = 246 ÷ 11.286 = 21.79 MPG (5/8/18)
Here we are up to date... 21.49 Avg MPG.
A better method of displaying my logs.
I've added a row for trailer towing. The first RV listed is a 30 mile round trip to town to fill the propane tanks and the water tank was empty. Roughly 7,500-pound trailer. The second was a 140 mile trip from home to Parma, ID. I filled up in Payette, ID and then continued on. The next fill will be also labeled towing being I still was hitched. There are roughly 15 gallons of water on board.
My biggest battle is I might start the morning with the calm weather then end up returning home with high winds and thunderstorms. Just when I thought I was going to record an awesome trip it's blown away by high winds.
Another note my current tune works awesome on towing. I've not updated the download of it yet. Level 3 (CanBus only) cruise set for 55 MPH on 6% grade will tip barely 1,000*F EGT's. You can stand on the throttle and it will barely reach 1,200*F never goes past. No back down used on EGT's.
BETA TESTING... CRAZY HIGH CRUISE TIMING.
DISCLAIMER - DO NOT ATTEMPT UNLESS YOU UNDERSTAND WHAT YOU ARE DOING!
I've learned something new I'll share with everyone.
Timing. I'm finding that some of the limits people been tossing out as protection but I'm finding that there is a way to crank these truck up pretty darn high in timing. At 55 MPH I'm running 1,600 RPM with 23 degrees of cruise timing. This has brought my engine load down to 20% on a 1% grade uphill from Riggins to Home. Put this all together now.
Current Timing - 15, 18, 22, 25, 28
Max Load Timing Offset 2*
Low PSI Timing reduct 5*
Timing Reduct Scaling 50%
Light Throttle Timing Adv 7*
Light Throttle Load Limit 25%
Yeap you are seeing that right. It's not a typo. 7* of Cruise Timing stacked on 15* of 1500 RPM band for 22* cruise timing. Now the reason for the 15* of timing in the 1500 band is because of the Max load offset it a -2* of timing. So as load goes down the amount of retard is increased. So just breaking over the 25% limit I see roughly 13.5* to 14.0* of performance timing based on load.
Now as you continue to add cruise timing you MUST pull Light Throttle Load Limit down lower. Don't leave it higher than needed to hold cruise state on flat ground. You will find that there is a very narrow band of load that engine runs smoothly without excessive knock exceed the load too far the knock get very pronounced. So when I started with about 4* fo cruise timing you can safely hold it for 30% of engine load. As I continued to raise the cruise timing I keep find that knock coming so as I kept heading up the engine load kept falling. Now my flat cruise engine load is just above an idle floating 12-17% engine load at 55 MPH
What I've got is a tune at 55 MPH climbing a 1% grade can hold nearly ZERO boost and EGT's floating 575-625*F and engine load stay below 25% most of the way no problem. The neat part is as the engine load crosses the 25% limit the timing drops instantly and turbo comes to life building boost to about 2-4 PSI to over come the increase of grade then as load falls the timing jumps back up and boost falls to near ZERO.
INFO: +75HP VCO Injectors (7 x 0.0085) and Hybrid 35/40 (60/60/12)
My timing has always been around that level. Never seen above 19 mpg when running like that. I've had timing as high as 28* before. No additional benefits.
Edited by trreed
Now if my weather would settle down and just be calm (winds) and stable temperatures I bet I can start reaching back up in the mid 20's. Seems like every time I come home from Ontario, OR the thunderheads start building, winds start up and the whole MPG number game goes out the window. Engine load rises above my break point and I lose the cruise timing for way more time than I wanted.
Just now, notlimah said:
Everyone would get the best mpgs possible if we drove in a vacuum.
Sure wouldn't do much for making compression or boost. Somehow diesel doesn't burn very good without air. :think:
Yea and just because all the conditions are perfect for one tank of gas doesn’t mean that’s what kinda mileage you get.
