installing solar on the RV
- Replies 17
- Views 4k
Mopar1973Man 7 posts
KATOOM 4 posts
01cummins4ever 3 posts
JAG1 1 post
Most of the time we dont have hookups. Generator and ample battery bank is sufficient for a good few days of get away. Solar would just reduce the generator usage..... Actually I prefer to camp
Some would say camping is when you have no electronics at all.(sleeping under the stars) Age has prompted me to reevaluate my previous opinions! We may all have a little different description of
Pros it's small enough to store the panels under your bed if you have the storage area. Cons is the panels are just enough to power a small 19" (IIRC) flat screen TV for the day. Beyond that, th
Looking back at some old threads I see some that have installed the Harbor freight RV solar kit, I was thinking of going the same route, just wondering if any pros or cons with that kit/ anything I need to upgrade? I plan on making it portable, but one thing I would like to do is wire in a inverter so all the 120 outlets would be available for power. Just looking for some input. thanks
also plan on using to 6v batteries They are about 215 ah. I hope the 45w panels are enough for charging, but I do have a generator for back up if needed.
Edited by 01cummins4ever
