- Replies 10
- Views 4.3k
KATOOM 2 posts
abner99 2 posts
Sycostang67 2 posts
Russ Roth 1 post
Popular Days
I like the block heater for working on the engine in winter. Really helps if you get a tarp up over the open engine hood and down the sides. Keeps a lot of warmth inside. I learned this only cause my
That's normal. If you store the truck in an enclosed shelter the temperature will be more like 100*F. The whole idea of keeping the wind off the engine and the dead cold off and allowing the heat to w
i used mine a fair amount last winter. Had it on a timer to come on 2 hours before I left for work. In 20* weather it would get up around 65* and start just fine. This was outside but mostly blocked f
So I'm pretty sure my block heater is on it's last leg. Been noticing it a lot lately. Just wondering what temp your engines heats up to before you start it. Mine the last couple days has been high of 86 scan guage said at 20 degrees out. Also does anyone know the torque for that block heater plug. Thanks
