Fuel Line Upgrade Question 2001 Cummins
- Replies 53
- Views 19.4k
Alexio Auditore 15 posts
IBMobile 4 posts
Me78569 4 posts
jlbayes 4 posts
I installed mine just over 4 years ago (5/2013) . Fuel pressure was 17 at idle and 19 going down the road when first installed then went to near 0 a few days later. I found a bit of debris from the
A new small pulley is installed to the front of the crankshaft pulley/ harmonic balancer and the pump attaches to the engine block via the front oil pan bolts. This is where the belt adjustment is al
Make sure you replace everything inlcuding the pickup tube in the fuel tank. When I first got my AirDog 11 years ago I was in a hurry to go up North to see a friend in the hospital so I installed it a
I've owned my Dodge for over 4 years now, and have upgraded the lift pump, which is the raptor 100 gph on the side of the block, edge ez, 4 inch exhaust, and I believe it has at least 60hp injectors that were installed by the previous owner. I am at 400 rwhp now, tested at the hunting for horse power up in cda. My question that I am asking, why is my fuel pressure dropping down 5psi at WOT? I have spent many hours trying to find information on this, and its hard to get a definite answer. the Diesel mechanic I take my truck to says its normal, but I know its not, especially since my truck will start to stutter if I let off the pedal after stomping into it for to long( by no means do I drive the truck aggressive, I drive it like an old man, like my old man lol) I want to upgrade my fuel lines to half inch from the tank to the lift pump, including fittings. but when I look online, I'm only finding the big line kit from the filter to the injection pump. Any advice would be much appreciated. I'm not looking to start a proper fuel psi forum, as I know its been beat to death.
15 psi at idle, 5 psi at WOT- doesn't seem normal. I'm on my second raptor 100gph -----this is my first post, let me know if I'm doing anything wrong.
Edited by Alexio Auditore
