I got a turbo from @CSM and I went ahead and got it pulled down to rebuild it. While its apart I figure I would measure out the turbine and compressor wheels. Here is what I got.
Compressor
Inducer 60mm
Exducer 83mm
Turbine
Exducer 60mm
Inducer 69mm
From what I found online this is a HX40 compressor wheel. The HX35W is 56mm compressor wheel. So this should be a rather nice boost (pun intended). Waiting for my bearing kit to come.
  • Replies 81
  • Views 28.6k
  • Yep, sounds like a HX35/40 hybrid with a 8 blade compressor.   Me thinks Mopar1973Man has caught the the power bug...
  • So fun fact of the day, there are two different versions of the HX35.  The 8 blade HX35's were 56 mm.  Then, Cummins quietly switched to a 7 blade version that's actually a 54 mm inducer.  I found thi
  • Mike was talking about checking his stock turbah, that's where my comment originally meant to apply.
Blade design is probably more important than diameter. Smaller will spool faster too.
Probably quite true.  I am waiting for a supercar OEM to come out with an axial flow turbo or axial/centrifugal turbo, complete with guide vanes.
1 hour ago, trreed said:
I'll put money down that it's a 54 mm inducer, as all 24 valves that i have seen have the 7 blade version.  Ironically, it seems as though the 7 blade flows more air than the 8 blade despite its smaller size.
It may not be off a 24V originally.  It came with my truck and lord knows where it came from.
Not sure we will ever see a turbo with an axial combo, it's just takes too much room and power... but who knows. I do know that the T700 I fly with has 5 axial and one centrifical and it can get to 17:1... but 75% of the fuel burned is to keep the compressor running!
I think we will see the reduction of diesel and rise of electrical in the next 10 years.  Things like turbo technology will slow and we will see the onset of the adoption of electric engines in pretty much all passenger vechiles.
I can't wait to have a 1 ton with no trans and a nice torquey motor....or 4 torquey motors, one per wheel.   talk about ABS :)
Or just the replacement of exhaust driven turbos with the 48V electric "turbos", in the form of a centrifugal supercharger.  That will be a sad day.
Edited by trreed
It may happen in some form, but I don't think it will be absolute, or even the majority, in our lifetime.
There is already a DOT war on pure electric vehicles and tax evasion. I suspect that hybrids will be more and more as they are cheaper to operate per 100K miles. The battery replacement on 100% elec vehicles puts their 100K mile costs much higher than most realize, but a hybrid can use a smaller battery and is still paying road taxes.
I think that small 1-2 cylinder turbo diesel hybrids will start to become more popular. They would be 30-40% more efficient than current hybrids.
I really doubt that technology is anywhere even close, if even possible. Think about the efficiency loss from a turbo to supercharger. Turbo's are using waste energy to increase airflow and superchargers are driven with fuel, almost directly since they are belt driven. If you make the blower electric driven you now have to turn fuel into electricity and then spin a motor which will not be as efficient.
The big reason you are seeing DRL's switch to LED's is fuel economy. It's estimate that using halogen low beams as DRL's reduces fuel economy ±1% and that's only 110w on a standard vehicle. In the late 90's when DRL's started become standard and all they mfgrs did was turn on the low beams with a relay the fuel economy loss was hot topic.
We have already seen a huge increase in turbo motors over the last few years and I expect that to continue for a long time. Turbo efficiency will get better and economy will go up.
The 48v stuff is closer than you think. The electric supercharger is a bit further out. Everyone (loose generalization) was all excited for Trumps view on the EPA.....they all seem to forget what has driven the tech and advancements over the years for passenger cars.
48v maybe, but electric forced induction would be energy prohibitive even if you could make electric motor 3x efficient as they are today.
Edited by AH64ID
This really should be moved into a new thread " engine and turbo future tech" haha
there are numerous things that could be put into place to help get efficencies up. but I still think the onset of electric is around the corner.  Batteries are not there yet, but a small effiicent diesel motor running a generator takes care of that.
As for combustion engines I would love to see someone start making use of rotary valves to get rid of the need for a complete valve train.  Independant valve timing / and speed would be pretty cool.  Compression brake on %50 of the cylinders or even cylinder disable with compression release.
As for turbos I have been watching some of the electric assist turbos.  Quick zap of power to get the turbo in it's map then exhaust gas does the rest.  I think Honda was toying with it.
We're just bantering while we wait for Mike's updates.....
Edited by AH64ID
There is no maybe. 48v is coming. BSG. F1 or Indy was messing with the electric turbo stuff but that is an extremely slow trickle down.
Maybe in terms in popular in everyday cars.
There is no doubt about the benefits of increased voltage across the board.
I got impatient... I finished up the turbo bolted it on and put my stock injectors back in. Forgot what turbo whistle was all about. This turbo is just a weebit laggy with stock injectors but once the Quadzilla kick in it will pull nearly 40 PSI of boost as is. So the +75 SAC's will be an awesome upgrade to this turbo. As for the Stock HX35W it measured 54mm on the compressor. I got to admit it was kind of fun clocking the segments of the turbo again.
What im curious about is how your mpg will change.
Hard telling right now till the injectors come. I can say from the little 30 mile trip it seem the boost pressure is lower at cruising speeds which I'm fine with. I'll see more tomorrow as I make my trip down to Boise.
