Looking for Staff Members
So I degreased the motor, and my mechanic friend stole my truck truck while I was out of town and replaced the hemorrageing tappet cover gasket. He pointed out that I have a crack in my exhaust manifold, and showed it to me.
That bumps up that repair to the top of the list. So I priced one at Orieley's and it's not too bad ($250ish). Are exhaust manifolds all the same, or should I stay away from the chain store part?
Any thing to watch out for, other than cracking bolts, etc?
  • Replies 20
  • Views 3.6k
    Hmmm... 15 years old and closing the gap on 300k miles and my stock OEM exhaust manifold still looks likes it new out of the box. Cracks? what cracks?
  • The only manifolds you should be considering are stainless one piece. Had a cracked ats, not impressed.
  • Going on 400k and no cracks. No sled pulling bud but some heavy towing.
If you can wait, look online for sales on 3 piece manifolds. They don't add power or performance, but a lot less prone to cracking. I got a 3 piece ATS manifold for under $300 a couple years ago when XDP had a sale.
5 hours ago, Mopar1973Man said:
Hmmm... 15 years old and closing the gap on 300k miles and my stock OEM exhaust manifold still looks likes it new out of the box. Cracks? what cracks? :shrug:
EGT's :stirthepot:
I liked my 3 piece other than it had a defect in the sealing surface and I had to have it machined when I sold it.
I really really like my stainless. Yes they cost more, but to me it's worth it.
Daily driving/towing or sled pulling? What are you egts during a run?
DD, drag racing, sled pulling. Never towed with it. Egts where as high as 1800* with it. It was fixed with braze once. And it was so hot enough times the braze displaced and settled. The stainless diesel manifold that replaced it, sees over 2k* with no signs of any issues. The only thing that annoys me is how long it takes to cool off.
jlbayes ....... any photo's of your stainless manifold ?
Like a header ?
7 minutes ago, Macarena Man said:
Like this
Are u on stock pistons or fly cut coated
Stock. Coatings do not last at these heat levels. I would never fly cut either. Compression is a good thing.
Edited by jlbayes
Like a header ?
Is there any reason to go stainless if the truck is stock?
11 minutes ago, jlbayes said:
There is no reason to change a manifold on a stock truck.
Absolutely true. Also, most daily driver trucks don't require upgraded manifold either.
Now performance trucks like TFaoro or Jlbayes now your talking another story these guys are pushing a lot of boost and lot of fuel and need the engine to breathe. Even with as much as I got my normal cruising boost pressure is still well below 10 PSI so I don't flow enough to even worry about upgrading nor worry about EGT's temps. Example 65 MPH I'm 2-3 PSI of boost and 550-600*F EGT's. This doesn't require an upgraded manifold.
Fwiw I've noticed zero difference when adding manifolds to the equation. Just ease of mounting turbochargers.
Unless of course its cracked like mine…but I understand what you really meant :-)
