Dead pedal at high boost
- Replies 28
- Views 6.4k
Pnwtree 14 posts
jlbayes 6 posts
Me78569 3 posts
Dieselfuture 2 posts
Interstage. Pipe between the two turbos on the compressor side.
We still need to know drive pressure and interstage boost pressure. Manual gauge is following the map readout on the quad right? Especially with a new setup involved.
Maybe cracked intercooler nwhen sertain psi is reached bam. Or could you be running out of flow in your air filter, take it off and try it.
Hi I'm new to the site but have learned so much and hoping you guys can help me out. I've been getting a dead pedal at 53-55lbs of boost, things I've done aside from power mods are auto to nv5600 and 2001 fuel filter with twist off cap. Power mods are on my profile. I've replaced apps, map sensor, made sure the quadzilla is good, have good fuel preassure, and great power till that specific boost. Any ideas would help. Thanks.
Edited by Pnwtree
