- Replies 14
- Views 4.1k
dripley 5 posts
JAG1 3 posts
portlandareae28 3 posts
Mopar1973Man 1 post
Popular Days
I might not have pulled my bumper off and done it but it did make everything very accessible and easy to clean with the pressure washer. This is why I took mine apart so far. The worst problem I
The tappet cover is under the intake manifold. Ignore the box for the 53 block
Check your tappet cover. If that thing is leaking it can go every where. Vacuum pump is another that comes to mind. That is my next oil leak to tackle. I did just replace my front seal. Had all
Just got back from towing for the first time with Mike ccv installed. I was hoping no catch can on the ccv was my oil issue on the front of the engine. Just pulled in the driveway and front pumpkin and steering is wet with oil again. Truck hasn't say long enough to see how much I lost in 250 miles but now I am ready to attack this oil leak which I am assuming its the front main. Any advice on confirming that or thoughts on anything else it could potentiality be?
Brian
