iQuad freezing with custom tunes
So after talking with customer support and getting my Adrenaline updated to V2 on the 4k box I decided to start building a tune. I started with Nicks DD tune and a started my test drive. Only made it a couple hundred yards and iQuad froze, to the point it locked up my tablet. I dont want to call Zilla back and waste their time since there is a plethora of knowledge here. is there an update for the app I need or is it a tune related error?
  • Replies 76
  • Views 17.4k
  • Quadzilla Power
    Quadzilla Power
    I've done some more testing loading custom tunes and are working on getting the app updated with some better user experience.  First, loading a V2 tune on a box that isn't a V2 box can take up to
  • Dieselfuture
    Dieselfuture
    You can send it in if you don't mind waiting, or you can do it yourself if you have windows 7, anything other then windows 7 gets to be tricky but @Me78569 has a wright up on it here  After some
  • Quadzilla Power
    Quadzilla Power
    I will upload the right version here in a moment. Sorry about that. I didn't think I needed to update here because the Play store had the latest version. But thinking about it. I should for consistenc
I got another drop on Thursday that looks very promising. I'm just doing some testing on it today and tomorrow then we will release it for Beta testing and then when it looks good we will push it out.
Of course, you can try the version this version if you are adventurous:
http://quadzillatech.com/TunesDownloads/AndroidApp/IQUAD_Android_app-release(1.9.40(56)).apk
I will try to get it uploaded here today too.
HAHAHAHA @Quadzilla Power I like to live dangerously!
I sat there for a good 5 minutes today changing power levels with that apk and it would not freeze.
  • 6 months later...
I went to install a custom tune this morning and the app told me that 33/43 variable didn’t load. Anybody else ever have that issue?
What does the build date sensor read when connected?
Data log menu item in the app.  connect to the truck, then go look at the data log, what does the build date show?
You can find it in the gauge palette or you can find it in the data-log like Me78569 mentioned above.
However, I will be very surprised if it has anything but 0. You are more than likely trying to run a V2 tune on a Legacy tuned Adrenaline. You need to update the Adrenaline box to the V2 tuning in order to use the V2 vehicle profile.
My box is maybe 6 months old I just got the system. How do I update it? I figured it would be pretty much up to date
It depends on what you ordered it with.  you can order the box with legacy tuning or V2 tuning.   If you did  not specify you prob got the old trusty 1000 series flash.
how you update.
or you can send it to quadzilla and they will update it.
Edited by Me78569
What tune did you specify on the order form.
Yep. The default base level tune applied to Adrenaline units back in September was the ADR2_1000 tune. Unless you specifically asked for the V2 tune you would have had the ADR2_1000 tune loaded by default. That has since changed and now we are shipping all of them with the latest V2.
In order to get your boxed updated, just send your box in to us with this form filled out.
http://quadzillapower.com/content/Forms/QuadzillaTestRequest.pdf
When we get it we will test it and update your tuning. There is a $15+shipping fee associated with the testing.
You can prepay here:
http://quadzillapower.com/adrenaline-module-test-and-update-for-dodge-cummins/
or you can wait until we test it and see what's going on with it after we get it. More than likely everything is fine and we will just be doing an update to the latest V2. We try to only keep your box here for 1 day. However, @Quadzilla_Stephenis going to be having a baby this weekend so we might be a little backed up next week.
-Thanks again,
2 hours ago, KBecker443 said:
 how do I go about sending my box in to get the V2 update
After some fun times I did it myself, at work I still have windows 7 and it's much easier. Good luck, you'll love it .
