Abs module goes out after 5 minutes
- Replies 42
- Views 10.8k
Alexio Auditore 14 posts
Mopar1973Man 9 posts
Chris O. 8 posts
dripley 5 posts
Kelsey-Hayes 325 EBC; All wheel ABS system: If ABS pump runs continuously even with ignition key off, the culprit is an electronic control module, which uses a transistor to switch the pump on an
That's why its nice to have @Chris O. on board he's one smart cookie for the Dodge electronics.
There are only a few things that trip the ABS light that I've found... Bad speed sensor(s) Bad tone-ring or misaligned tone-ring. Metal debris in the tone-ring or stuck to the end
Ok guys I need some input. I just got my abs module back from Module Masters and put it in the truck and what do you know, no abs light, motor isn't continuously running, Yes! So stinking happy. Drive about two miles, getting off the freeway and look down and see the abs and brake light on. Crap. So I get out of the truck,open the hood... The motor is running. So module Masters says they will take of it, they didn't hassle me whatsoever, which is nice. But my question, could something be going through my electrical system and causing that relay or whatever it is to fail? I'm guna order a fluke ( either 114 or 115, not sure what would be better) and test the alternator for ac noise. But can it be another issue? Two years of the abs light staring at me, I want it gone for good.
