Which injectors for compounds?
- Replies 17
- Views 8.2k
jlbayes 6 posts
Cronus577 4 posts
Dieselfuture 2 posts
Me78569 2 posts
7x.010s or just jump to a 6x.013 and back fueling down A LOT.
extra pop is just to try and get less smoke, I don't know that the timing difference would be much, just a guess though. as for tough on the vp44 I have a hard time swallowing that pill
They will be at 290 bar. Mine had orings and washers on them when arrived. I did change connector tube orings.
Looking for some advice on which injectors to go. I currently have DAP 7.009 SAC (100hp) and was looking at going bigger to match the compound turbos I'll be putting in. I'm currently running a Borg Warner S475/92/1.10 over stock HX35 with the billet Wicked Wheel 2 compressor blade. I'll be doing light towing every once in a while ~6k lbs. Also switching up my setup from an EJWA to an Adrenaline so I know there's going to be a lot more fueling customization once I learn the unit. Anybody have any suggestions on a good clean burning injector that would match my setup?
