- Replies 25
- Views 7.1k
Mopar1973Man 9 posts
notlimah 8 posts
jlbayes 3 posts
Russ Roth 2 posts
Here's the rundown... A stock 47RE valve body is not capable of lockup until 2nd gear. The lockup valve in the lower VB is fed fluid by the intermediate apply circuit, therefore no fluid t
I'll admit the work @Dynamic did do to my valve body made a huge improvement even towing with the 1996 Dodge. Hold back much better and pulls excellent without getting hot. I just ran it down to Boise
Laguna's grade is no joke that's for sure. Driven up that 100s of times! As far as your trans temp, where are you reading the temp from? That'll sorta sway the answer one way or another fo
So the entry road to the Laguna SECA race track has a 16% grade and my trailer weighs just south of 10k pounds. No way to get enough speed to lock up the torque converter. So I'm stuck crawling in 1st. I had to run for a few hundred yards with the transmission temp gauge north of 280 degrees. Ouch. A high idle at the top of the hill brought the temp down quickly.
The fluid doesn't look or smell burnt. I think I'm going to have it flushed out anyway. What are the chances that I damaged my freshly rebuilt 48RE? Is it typical to see the trans temp get up around 220 before TC lockup? You know - on a hot day leaving stop lights and such. As soon as the TC locks up, I can literally see the needle move back to 180.
What do you guys do in these situations? Would a transmission cooler fan help?
