Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 80.4k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
2 hours ago, Me78569 said:
I have the lowest stall converter Revmax sells. even with temps near 0* my truck will not stall when I put it in gear.  I would love to know why, but Kole isn't having issues either.  The only way I can make the truck stall my blipping hte throttle over and over if I do that ~30 times it might stall once.
I believe it happens, but I dont see it in my testing, confused.
It happened to me with some 7 hole nozzles and a tight patc converter. If you let the truck warm up 5min it would not happen. Cold start 20* and below if you pulled it into gear it would kill the truck. Reverse or drive.
2 hours ago, Carbur8tr said:
Can you expand a little on the fuel comment?
Also a tight converter would certainly not help, injector aside, but the high pop pressure we are testing.  Both @Me78569 and @kzimmer have been successful with their high popped injectors.  I hope to add to that sometime this weekend if I get the time to install them.   Up until this point most of the information on injectors has been hearsay. I don't discredit those who build injectors, nor do I think that they are necessarily wrong, but a thought we do have to consider is that they have an agenda and they have to make money.  What the general population wants and needs does not always fall in line with those paving the way for a different thought.
I believe what Nick is thinking the ecm is pulling fuel to control idle. When the gear lever is pulled into gear the fueling command is so low and the converter pulls down the idle rpm too fast causing the stall. If I am off base on your thinking @Me78569 correct me please.
These were 7x.010s. I will not name the nozzle source as to give him more adverting on a google search. Most of you will know who lol.
@jlbayes what size injectors where those 7 hole?  What pop pressure?
You are thinking what I am.
Example with %'s
The theory I have about this is, made up numbers,
Stock injector size
say a truck idles in P at %10 fueling, then when put in gear the needed fueling should be %20 to keep idle rpm.    The ecm must "react" fast enough to ramp up fueling.
7 x .010 injector size
say a truck idles in P at %8 fueling, then when put in gear the needed fueling should be %15 to keep idle rpm.    The ecm must "react" fast enough to ramp up fueling.
7 x .012 injector size
say a truck idles in P at %5 fueling, then when put in gear the needed fueling should be %10 to keep idle rpm.    The ecm must "react" fast enough to ramp up fueling.
The ecm doesn't need to work as hard to adjust fueling if your injectors are bigger.  If that fueling adjustment needs to happen in 1/10 of a second to prevent stall then the ecm has a better chance to adjust fueling as injector size gets bigger.
Now we know that pop pressure adjustments can lead to stalling issues,  increasing pop decreases duration.  So the idle % range becomes wider since duration is shorter.  It makes sense in theory that the bigger injector you go the room room you have to play with pop until you run into issues.
that brings us back to injector size vs pop pressure and where the issue comes about.   What we still are %100 unsure of is what is the actually fueling duration lost per bar of increased pop.  Does a 7 x .012 at 350 bar flow the same as 7 x .011's ?   How much power is lost as a result of pop pressure increase.
I have a theory that the larger the injector you have the higher the pop you can run without issues.
I think this theory is sound.
7x.010 nozzles and 310.
Patc low stall converter at the time. I kept the same converter up until killed the trans when ppumped. It ONLY stalled with the 7x.010s. Same shop pop tested the 6x.013s and set them to 310. No stalling issues, ever. Which falls in line with your theory.
So I wonder what size injectors weston tested with.
I tried to kill my truck by blip throttle on a down hill while in reverse and I could not get it to die.
@jlbayes do you know of any dyno graphs showing the increased hp as a result of lower pop?  Curious to see how much lower hp was going form vp pop to ppump pop.
None, I doubt you'll get anyone to give those up. I can tell you both Seth and Weston have a pop pressure they like to use for a reason. As well as Don at F1.
It would just be really cool to get some real world findings rather than two people, or more just repeating the old because I said so" over and over again. It really seems like there was some small amount of testing done with higher Pop pressure with some small negative effects and it was just given up.
It was given up on due to issues with lack of tuning. Y'all need to keep that in mind. There are 2 people that were extremely big into the mechanical injection side. One of them still is. Everything we are being told is old. Yes it has been tried with no success as they had nothing capable at the time to make these work. Weston picks and chooses what he works on.....like Cody found out. This idea is in a very very narrow part of the market. That is ever shrinking due to newer trucks becoming less expensive to buy. None of the ideas or push back are the end all be all. We all have different opinions and expectations.
I can Agree  with that... I'm still willing to put time into learning more about it though haha
Absoluletly agree.  I don't fault them for not wanting to, it their product that's fine.   They are just not the right guys to be building injectors for us who want to mess with this like this.
like you said it's a dying VERY small market we are talking about here.   My desire to play should not put someones business at "risk"
Nick your theory makes sense.  Would like to see more testing out there.  I imagine that if you know the flow of the nozzle and the reduction in pulse width one could tune and figure out the correction factor in tuning from running 7x.010 to 7x.013.  With limitations of the VP44 and other variables it would be hard to isolate it exactly.  I do not believe it would be linear (which would make it easy).  Wish I had a dyno here.
I wouldn't so much say risk as much as the publicity that goes with it when someone that does not understand what they are getting into asks for something special like this. You and the people in this thread have an expectation of what is going to happen. Joe blow that wants the super duper special nozzles and higher pop because bookface said it was cool won't. Is just a headache for them at that point. I see both sides of this, I really do. Fwiw I tried to get Weston to open up to it. Is not interested lol.
I can see that side too, but it's not that much different than the same Joe Blow that wants to run 300 horsepower injectors on his otherwise stock vp44 truck with no lift pump or upgrades of any sort. That happens almost daily
I dont blame him, why fix what isn't broken?   His injectors meet the goals of what he wants them to do.  He is proud of them as he should.   He shouldn't be forced to "play with stuff"  America!
If I want to play with this I should have to find someone willing :)   which I did hahaha.
I think anything that can be done to improve efficiency, better control over smoke and power is worth looking at. If there are many negatives then its not worth it.  Would like to offer custom pop off pressures on the website so customer can determine the pressures (option box so if they want lowered pressures for P7100 or raised for quadzilla custom tuning) it would be an option for the customer.
The stalling thing is also of interest.  I know people even with rv275 and tight converter that stall constantly in reverse.
For most people it is a moot point as they won'y do anything with it.  Curiosity has a hold on me and I want to support it.
When I watch the canbus message when I put it in gear what I see is
1. shift into gear
2. rpms VERY briefly lug down
3. canbus fueling spikes to ~1500 or %30
4. rpms spike as a result of the fueling increase
5.. canbus fueling drops nearly to 0 to keep rpms in control
6. Rpms lug
then rinse and repeat until rpms stablize.  the entire above only takes 1/4 second
as for a customer option on pop pressure,  I think that is a cool thing to offer.   I would say however that it comes with an "extra fee"  with a free repop or something like that.  also there should be a limit based on the injector size.  IE a 7 x .009 shouldn't be popped above say 310, 7 x .010 at 315 7 x .011 at 325 7 x .012 at 340   and so forth.
I believe line 5. is what causes the stalling.
Edited by Me78569
Don's f1 220hp injectors in my truck with a 2-300rpm lower than stock stall converter (see firepunks site) will stall my truck when put into reverse when cold. I throw it into first, then reverse, and it won't stall. Typically just needs to do that once unless it's real, real cold.
@rogerash0  When you put it into gear do rpms spike for a split second or do rpms drop without any spike at all? even just a split second spike
