I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 68.9k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
No clue, my truck doesn't have TM so I can't tell you how it interacts.
Throwing the canbus at %150 across the board and a ton of wiretap will try and overwhelm TM, but the longer you spend in the 1 -25 mph area the more tm will pull fueling.
So this new tune is like 2 step but fr our trucks then. Sweet. Does this work on a manual transmission?  If so I want to try it
You can't put load on the engine enough to build boost without roasting the clutch.  It will in theory work, but I am guessing your clutch will be smoked before you launch.
If you give me some beer I'll try it with the dual disk....
But I actually like my trans in one piece.
Edited by trreed
Also where in the quad does this code get written? Or is it tune of some sort. Sorry if it is a dumbass question, still learning the V2.
It's a difference base flash.  so the box under the hood gets a different flash, with 1 line of code changed to use the bosot defuel for staging rather than overall limit
So say I had the 2.7 flash, that gets replaced with a different flash or a 2.7 flash with the added line of code?
the 2.7 code would be replaced with 2.7+staging
But again this code is a race only type of thing.  Using the staging function will cause unbelievable stress to the drive train
Can you write a code for a 2 step type of deal for us manual trucks
Edited by Ekillionc9
no, manual trucks cannot apply load to the engine at idle without slipping the clutch.
Without a load to apply the engine cannot build boost
Anyone want to do full auto swap for my nv4500????? PLEASE!!!
Haha this sounds fun, mabye after I get this tune dialed in lol.  It's almost there.  I think we made some good head way today but the truck was covered in ice including the mirrors so no telling what was behind me.
I have tossed this up time and time again.  I think I just need another truck that has an auto already in it haha.
Yep.
2 step doesn't load the engine it just limits rpm. I think it has an upper and lower limit. So say you set it at low 2000 and high 2100. It would bounce the Rev limiter between the two specified limits.
oh, yea nope can't do that either.  the ecm gets VERY mad if you mess with fueling vs rpm.  the ecm goes into a runaway mode protection and shuts off.
I'll just take the NV4500 for a spare... :whistle2: Don't have a 47RE to give up. :broke:
If u were close he'll ya
Lol where are you at?
This doesn't seem like a very good trade on my end lol ha ha
2 hours ago, kzimmer said:
Yep.
I'm not joking! I have really been considering this!
