Installed 19.5's on the Pimp Truck
- Replies 47
- Views 15k
01Cummins3500 13 posts
Mopar1973Man 11 posts
AH64ID 7 posts
banzaitoyota 4 posts
I went with the Vision wheels and I got them from Discount Tire. I checked prices at Bruneel, Les Schwab, and the internet. Internet was cheaper than these dealers. Discount Tire doesn't do 19.5 tr
If it turns out to be a balance issue then you may have to add beads to the tires. I don't recall how much out of balance the Centramatics will correct but beads will enhance the out of balance corre
Looks good! My 19.5's with counteract balance beads are amazingly smooth.
Well I haven't posted here in a while, mostly because I was super busy and hadn't had time to play with the truck. But I did put some used 19.5's on it a couple of weeks ago, and I couldn't find many pictures of these on 2nd gens so I thought I post a couple here.
I have to say that I have vibration and the centramatics didn't help that at all. So I'm thinking either the tires are worn unevenly, or I have other issues I'm not aware of. Going to start working on that soon.
Anyway, I hope you enjoy the photos. The top is the "before" with 4th gen 17" 235/80, and the bottom is "after" with the 245/70/19.5.
