- Replies 7
- Views 2.6k
Me78569 1 post
NightHawk 1 post
Cronus577 1 post
AZ2ndgen99 1 post
Popular Days
It won't build more boost unless you get a boost fooler on the ecm. Anything over ~24 psi and the ecm will defuel.
Like @Me78569 said, need a boost fooler and I have one for sale for a 99'. You would also benefit from a boost elbow so you can change when the wastegate will open. As far as the stock motor, 45+ psi
I don't belive my wastegate is operating properly and I'm looking at replacing the actuator. Now for the rookie questions. Should I go for the stock replacement rated to 21psi boost or spend the money on an AFE rated to 40 psi? And . How much more boost can the stock motor with 150,000 mi take?
Edited by AZ2ndgen99
