- Replies 11
- Views 12.1k
Dieselfuture 4 posts
CUMMINSDIESELPWR 3 posts
Towrigdually 1 post
Cronus577 1 post
when i did mine first time (during clutch replacement), i used a small drill bit to start a hole then used self tapping machine screws at 3'oclock and 9'oclock to drive in then pry on. you work the ol
easier with backplate off for sure. i didnt have a new gasket for the seal backplate. but if you have a gasket, take the plate off as its aluminum and easy to score, then you are screwed.
Then it's back to good ol rtv
I'll be ordering a new clutch here soon and I know my rear main is leaking so I'll be doing them at the same time.
So with that being said, any tips to taking it out an how to install it? I don't wanna play with an $80 seal and do it 2-3 times before I get it right.
