Adjusting/ tightening steering box/ wheel play
- Replies 10
- Views 6.4k
Mopar1973Man 4 posts
dripley 3 posts
JAG1 1 post
LorenS 1 post
You'll be surprised I've seen some boxes where I turn 3 to 4 turn just to find bottom again. Then loosen 1.5 turns. That means if you doing 1/8 turns that would be 12 times of adjusting and test drivi
I guess I have to base mine on my past experience with a S-10 Chevy. Cranked way down on it and it turned like a dream in the parking lot. Jumped it out on the road and when I went for second the truc
For anyone reading this in the future, my truck (likely stock steering gear) required a 3/16" hex key and 5/8" wrench. Either a stubby or ratchet-wrench would've made this project super ea
I think I remembered about certain things you when adjusting steering play. Don't bear down hard on the adjustment screw, turn wheel back and forth making very small adjustments each time, raise the front off the ground....... That sort of thing?
Thanks for any advice.
BTW, My truck knows the way to
these kinds of places
