- Replies 12
- Views 3.5k
They are? I have never seen a flare fitting used on the front calipers of these. @dave110 take a hammer and smack the banjo bolt. Snug again with wrench or socket.
Dave, The copper was too hard. Happens a lot with steam systems. ( the copper should be dead soft and pure, but copper is expensive so they add tin, aluminum, zinc.... and they don't ann
Treated the truck to new front pads today. The one caliper was kind of sticky so I put 2 re-man calipers on as well. Got it all bled out and went for a test drive and it all works well. I swear I can feel less rolling resistance. Got back and checked things over and noticed fluid weeping from the one banjo bolt. Checked the other one and same thing. In 30 years of doing this I've never had this issue. I tightened them a little more but I just can't get the copper washers to seal. I'm considering putting the old ones back on. I'm confident everything was clean when it went back together. Anyone ever have this problem and have any ideas? I hope this won't be like getting injector lines to seal.
