- Replies 14
- Views 2.6k
Me78569 4 posts
rogerash0 4 posts
Dieselfuture 2 posts
Quadzilla Power 2 posts
there is a build data field in the data log. that will tell you what date the flash was created on. You can't correlate to a vehicle profile as the profile is what defines sensors, but not the tu
I agree, can we get all the other vehicle profiles off there, old versions like 1.9, 2.2, 4k when I dont have a 4k box (unless I can run it, then please give me the option), and if its safe to run v2.
Yep. I just got word though that our developer is out until January Its going to take some time to fix this bug. Work around for now is to wait until after your done loading the tune then start c
I need to bring this up to @Quadzilla Power ... The user interface is needing some clean up.
Vehicle Selection - Way too many Dodge versions floating in the vehicle selection. I've seen several times where people are asking which version do I use to get X new function. This needs to be cleaned up. Just in V2 there is 2.2, 2.4, 2.5 and 2.7... The vehicle listing should be separated Chevy, Ford, and Dodge. Then the versions of code V1 needs its own category then V2 in its own category. This will reduce the amount of problem for newbies and know what to pick. Any BETA version should be listed in a separate category.
Menu Icon - Menu icon size never got resolved even with a newer phone switch from LG G3 to LG G5 its still tiny icon. With my phone case on its even more difficult to get the menu to pop up.
Hidden timing feature - This needs to be changed up as well. I noticed that @Me78569 added a stock offset feature only if the other settings are set to ZERO. This will go unnoticed by many people. I highly suggest you add a toggle or switch to change the parameters on the screen so it's more user-friendly.
