- Replies 37
- Views 9.9k
JDHudsn 13 posts
jlbayes 9 posts
Dieselfuture 3 posts
Silverdodge 3 posts
Think of the turbine as a lever. The longer (larger diameter turbine wheel) the lever the more leverage you have on what you are trying to move.
I'm kind of the same way I hate to spend large amount of money on parts I'm not certain of. I tend to come here and lean on the guys for assistance and helping me pick the right stuff. The neat part i
I've run both of those turbos. I have slightly larger injectors than you do (by a whole half of a thou!). Currently running the 62/68/12, and with the v2 tuning, spooling after a shift is no problem
Ok guys I am having to replace my head gasket and while I’m at it I decided to put in a new turbo..... after a ton of searching I am no further along in my quest to find the turbo I want. With all the sales going on next week I’d like to take advantage of it!!!
-I would like 500 ish horse power
-this is my daily driver
-I tow a 10,000lb horse trailer once every other month
-I’m running a FASS 150
-ARP Head Studs
-HX40 down pipe
-Quadzilla V2 tuning
I’d like to pick the right turbo so I don’t regret my decision down the rd. I am torn between a few turbo sizes...
-S364/68/.70SXE
-S362/65/.70SXE
-S300g (57/60/12)
If you guys guys had the opportunity to start fresh with a new turbo what would you purchase?
Hopefully you guys can help me reach a decision!!
