Quadzilla Adrenalin power wire fuse
- Replies 17
- Views 6.6k
Mopar1973Man 4 posts
Carbur8tr 4 posts
Dieselfuture 3 posts
Me78569 3 posts
Just my experience, my box stays plugged in to a 10 amp jumper in the fuse box by the battery as well as the jumper in the cab at all times. I believe that that module has run just off of the jumper
I wouldn't worry I have unplugged my box literally 1000's of times without issues. It's not a bad idea, just not really needed. I dont however know the draw of a quad box.
Actually the draw will be the same as fuse you tap in the cab which IIRC is 10 amp. The Quadzilla passes power through the Battery lead to the Ignition trigger during cool down.
I believe it's been discussed before, but I need a straight answer on adding a fuse to a power wire going to a battery from the quad. Reason I'm wondering is every time I unplug the main connector to the box to flush it, something always clicks and I don't want to unhook a battery lead every time, plus if I do by the time you get it off it will click a few times anyway so it's almost better to just unplug the box. So I want to put in line fuse on positive feed, but don't know what size. That way it will be protected for whatever reason and won't be clicking a bunch of times. I'm guessing it will probably still click ones when I pull the fuse. I don't know I'm just thinking out loud and not sure if fuse is even needed.
