Electrical bug! Bad ECM
- Replies 56
- Views 18.4k
JP907ATB 22 posts
Mopar1973Man 11 posts
Me78569 5 posts
GSP7 4 posts
It sure can. 00, 01, or 01.5 are the prefered ECM's. You can get ahold of me on our support system @ www.smartyresource.com with the truck information and I can have my programmer build the truck
that was me. the oil pressure sensor shorted internally and caused the entire 5v system to go wacko.
FYI... The actual Smarty support site is SmartyResource.com. They also do VIN unlock and recovery files as well. https://smartyresource.com/support/
1998 cummins 5.9 24v having problems with po113 code, cannot erase, IAT sensor reads -40 in live data. That reading dose not change if i unplug the sensor, leave it plugged in, or put a jumper in the IAT plug, it reads -40 no matter what. I am pulling 4.8v on my multimeter at the IAT plug with both test leads in connector. I put a 2.7k ohm resistor in IAT plug and i can clear the po113 code and run truck, forcing IAT to read around 114. How ever something is forcing the truck into high idle and then what i believe to be 3 cyl high idle. It dose this if i run truck without resistor in and check engine light on to. I have checked continuity on both IAT conector wires back through ecm plug, along with the wires for the CTS and MAP sensor. They all tested good when i ohm tested them. I have also replaced the IAT sensor CTS and MAP sensor. I pulled IAT sensor and check resistance on it and it seemed good still as the reading dropped when i put heat to it with blow dryer. I also took alternator to local Oreillys and had it bench tested 6 times and it passed every time, (i knew for sure it was charging but thought maybe bad diode.) Also have to brand new batteries, and have researched ground locations and cleaned every single one to shinny metal.The truck also has smarty but programmed to stock, along with edge juice with aditude which is completely disconnected. However before i disconnected it completely it said the ecm was getting 14.2 volts with truck running is that normal? Also the truck has a high idle kit of some sort installed but it works fine, actuator type mounted under throttle housing. It only allows high idle at 1200 rpm and works fine whe. Engaged and dis engaged. I have run out of ideas any input would be greatly appreciated.
