HVAC Question (Heater Core replacement)
- Replies 18
- Views 4.4k
Bobalos 8 posts
Mopar1973Man 4 posts
dripley 2 posts
BBHD 1 post
I was talking about my hand held vacuum pump to test these vacuum pods. I'm know where that one is, I just replaced it and dammit was that expensive..... Lol. I think I hav
On a previous job, I used the same weather stripping tape just wrapped around the tubes to fill the void. Something that is wide but not overly thick.
Evening Folks,
I probably should have posted this up a couple of weeks ago, but it just occured to me. Im fixin to pull the HVAC box out & replace the heater core & AC core (& replace the dash & fix the EGT gauge), & figured while I had it all out I should check the vacuum pods under there. I saw from Mikes video that there is one directly on the HVAC box, but I dont know if there are other ones up under the dash (I would suspect there are as there is a bunch of vacuum lines connected together in the middle of the dash).
How do you test them? apply X amount of vacuum & it should hold that for Y period of time? or is it enough that if I apply vacuum & it moves through its entire stroke then its good??
Also, is there a vacuum diagram for this truck? I looked through my shop manual & could not find one & I figured there would be one under the hood, but there is not...
thanks folks.
Bob
