- Replies 32
- Views 6.8k
leety 12 posts
dripley 6 posts
Dieselfuture 4 posts
Mopar1973Man 3 posts
Vulcan Performance sells the big line kit for the stock filter to the VP44 injection pump. http://www.vulcanperformance.com/Universal-Big-Line-Filter-to-Injection-Pump-Kit-p/ffipn375.htm
I dropped the tank, not hard to do. A lot of folks tilt the bed, sounds easy to do too. Never done that so I can't compare. I have a5th wheel hitch and decided to just drop the tank. I do all my work
Fuel sender is pretty cheap and can be purchased at you local dealer. Make sure you keep after parts guy that you only want the level sensor.
Every new day brings a new discovery!!
So today I destupided (it's the blond streaks I can't help it) and learned from this site, that I was exiting the turn key switch 3x trick do dump codes too soon, as a result I was missing out on all the fun of getting the 2nd code.
I pulled 2 codes from the PCM I got a P1693 and from the ECU I got a P0230.
Mind you, I was unable to pull these codes with any ODB2 scan tool. I've tried 3 different ones. I still can't pull either of those codes with and ODB2 scan tool, even with the connector disconnected.
I followed these instructions and when I took off the connector, and I was super careful about it, the yellow wire broke off right at the connector.
I was unable to get a reading for ohms of any kind when measuring the ground pin on the fuel transfer pump connector at the unit.
The weird thing is the truck was seemingly running okay prior to all this. I had just changed the fuel filter and got a fuel pressure reading of 14-15 psi.
So the question is should I just decommission this poorly engineered pump scenario and move forward with a FASS Fuel system and upgrade to 1/2" lines rather than fighting the battle to fix this one?
