- Replies 55
- Views 12.3k
01dodge24v5.9 26 posts
Me78569 24 posts
Mopar1973Man 2 posts
kzimmer 2 posts
Start with this. This is the V2 bible. The Gospel according to Nick. 1psi fluctuation sounds ok to me. If you're worried about it you could probably put a snubber valve before the
I've recently installed a quadzilla adrenaline with BT unit on my 01 dodge. I have 7x10sac injectors, s362 turbo, head studs, 4" exhaust, new vp44, bhaf, fass 150.
I did not wire tap it due to having a new vp44.
First, I'm kinda lost on where to start with adjusting the tune in the quadzilla.
What's safe?
What I can change without wire tap?
I've seen the down loads on this site 1.9.4 (app?) and the 2.7.4(tune?) What are these?
Second, I get a bounce in my fuel pressure gauge (quadzilla kit) by about 5psi (I'll attach a short video), I'm running a petcock in line to the sending unit. With it turned almost close I can limit the bounce to about 1psi... is this normal? Or do I need to get my shovel out and start digging around the fass system.
Thanks for your help!
20171219_180139.mp4
