Oil pressure drops when temp gauge goes up
- Replies 7
- Views 2.2k
AH64ID 2 posts
Mopar1973Man 1 post
dripley 1 post
notlimah 1 post
Popular Days
Just the design of the oil pump and lubrication systems. On a diesel there is much more pressure on the bearings due to the high torque and low rpms, this demands more oil pressure and th
As those guys said it's probably a fake gauge, but with your 2000 it could be correct. Something like a M9173M fast idle kit would let you know if it's real or fake, as the pressure would change depen
Hi there guys names Rick, I’ve had my 2000 Dodge Ram 2500 for about 4 years now. Since I bought the truck the oil pressure is well above 40 pounds when I first turn truck on. After the truck temp gauge goes up the oil pressure drops below 40 at idle, if I give it some fuel oil pressure goes up. I saw a video of mopar1973man on YouTube explaining that it’s an electronic issue between the two sensors. Is there a fix for this? Thanks for any help in advance
