50 hp Injectors
  • Replies 37
  • Views 10.7k
  • I really dont think there is a need to increase pop on small injectors.  I dont think you will find anything other than issues.     My theory is that as injector size increases you gain more
    With everything, Nick @Me78569 is learning about pop pressure my next set of injectors might be 100 or 150 HP injectors. Even my current injectors I'm going to have to pull them and re-pop to 315-320
    Takes me 1.5 hours to change out injectors on a hot engine. Ask @hex0rz about his swap I did at 7pm at night in my yard.
Can I reuse copper washers or better to get new?
1 minute ago, Mopar1973Man said:
Ahh... DAP injectors come with new o-ring included. :wink:
Remember that I'm using the DDPs I have.. :popcorn:
I would guess standard it may depend on nozzle style, dap should have all o rings and washers you need, I have purchased them directly through Cummins before.
Sac
I'd just call them and ask to be sure if that's where you're getting them from or tag them here. I'm just guessing on washer thickness style dependent, I don't think it's sac vs vco more like thickness of nozels where washers go, some may be machined differently. I would think most will use standard. It also may have something to do with spray angle, where in the bawl it will spray, I'm just thinking out loud here not really sure.
Right on. I was thinking I would get them from Cummins but somewhere on CF I read that someone paid over 60$ for a o ring kit when you can get much cheaper at DAP or elsewhere. I called the nearest diesel shop and they have everything I need but theyre 45 minute drive. Ill prob end up going and getting from there. Anyone have tips or tricks for injector swaps? I reads @Mopar1973Man article on removal and install so I feel comfortable digging in.
LOL! I expect it to take me a little longer but we will see! With your article to help me it should be a breeze! How hard is it to access injectors 5 and 6? Of course there is some brackets and parts that need to be removed for access.
2 minutes ago, Mopar1973Man said:
Just the rear hoist ring with two 15mm bolts. Just pull all the 10mm bolts holding the injection lines. 8mm bolts in the injector hold downs. Apps sensor and intake horn. That's about it.
Shouldn't be hard! Looking forward to this extra mpg and power lol. Only thing I'm not looking forward to is a toasted clutch. I was talking to someone about it and they acted like injectors would slip a clutch faster than a tuner. Is this so? I have yet to slip it with an Edge Juice. Guy I bought my truck from said it was the original clutch but who knows.
This is off topic but 98% of the time when I go into reverse it wont go unless I sort of ease the stick up and k=let the clutch out at the same time. Is this a sign of my clutch going south?
Most likely not. Mine 6 speed is like that has been since new. The second one too, on both new and old clutches. Sometime she goes right in and others not. Sometimes I will drop into a high gear and then to reverse and it slips right in.
Exactly what mine does. I’m sure it’s just he norm
So I found out that these used DDPs are stage 3 100hp injectors. I’m not sure I wanna run that big on my hx35. Should i run em or sell em?
  • 2 years later...
i have  a 2000 dodge cummins with a banks tuner and its got the 5 speed automatic trans, would i hurt it if i did 50 horse injectors?
assuming your truck isn't in bad shape then you should be fine.
Correction its a 4 speed auto transmission 47RE in a 2000.
An automatic transmission is weak in stock form. Personally I would go from the Bank to Quadzilla this way you have control of timing for MPG purpose and then you can write a good light defuel curve to launching with an auto to prevent damage. You can start off with a fair amount of defuel and then grow it up on the upper end preventing transmission damage. This is not possible with a Banks tuner. Banks is a canned tuner designed for stock injectors and stockish timing.
Like my "Economy Tune" start off light and keep the power down till about 12 PSI of boost then by 15 PSI my wire tap can kick in for added power but done cleanly no smoke. Being I've managed to shear off 5th gear at 80 MPH. But the wire tap is so high that I never reach wire tap in normal driving.
You can tune the timing in and gain upwards of about 2 to 4 MPG if done properly. Most canned tuners are designed strictly for stock injectors. Now adding larger injectors typically you have to start advancing timing.
  • Quadzilla Adrenaline 180 HP
  • DAP 150 HP injectors (7 x 0.010 @ 320 bar)
  • BHAF
  • HX35/40 Hybrid turbo
  • 4 inch Diamond Eye exhuast
  • NV4500 Transmission
  • 3.55 Gears with 245 tires with a final ratio of 3.69:1 to the pavement.
  • 422k miles and clocking!
