- Replies 18
- Views 3.9k
Marcus2000monster 9 posts
JAG1 3 posts
dripley 2 posts
dave110 2 posts
If I could add to this, if you can’t find the noise, what makes you think a mechanic will? Most mechanics won’t give it much time, if the trucks running right, it’s fine. Unless it’s blatantly loud, t
I had a cracked rotor n my Pstroke one time that ticked every time it went through the pads. Just a thought............
Plan to keep the truck forever. I'm definatly not afraid to do anything as I even plan to rebuild the engine when the time comes. It was all before the valves and injectors. Its been going on for 3 mo
I have been having a ticking noise from the engine that seems to parallel the rpm of the engine. it only becomes noticeable when slowing down for a turn or stopping. I have checked manifold for cracks adjusted valves and all new injectors. Hold down clamps are tight... Any other suggestions before I take it to the Mechanic to double check valve lash and diagnose the ticking?
