- Replies 10
- Views 7k
Dieselfuture 3 posts
Judge 2 posts
mountaindan 1 post
jlbayes 1 post
I'm sure they do, EPA is not going to reverse their thought process, they probably just came up with different solder. But then again that's just my opinion.
As far as I know that all certified rebuilders have to replace the PSG module with a Bosch supplied module during the rebuilding process. Rebuilders are not supposed to re-use the electronics. So this
I did not dig to deep on this but Blue Chip still offers a pump with a used upgraded PSG on it; I know they do not build their own pumps so that has to make you think.
I have a 1998.5 dodge cummins I pull a 40 ft trailer with it runs good untill warm up then goes in limp mode has codes po743,po463,p1693,p1690 it only goes in limp mode on days that are 70 degrees or higher and will fix itself if temp outside drops below 70ish
