idles at 800 and revs to 1400..thats it
- Replies 40
- Views 7.4k
snowshoveler 14 posts
Mopar1973Man 9 posts
dripley 5 posts
Marcus2000monster 4 posts
Popular Days
This my thought too, when looking at the map connection its a signal that perhaps the rest of the electrical system needs a lot of attention. Electrical can be really weird, just my theory, but one p
Unplug apps and see if it will idle normal, ecm controls idle, if it will go up it's ecm if not maybe something wrong with apps, ditch the factory style and get a timbo, no more problems.
Very rare indeed. Most here only dream of having DRBIII tool.
Truck in question is a stock 99 with a 5 speed. Only mods are a fass lift pump and 1/2 inch lines.
Like the title says the truck will idle fine and when you give it a bit of throttle it will jusm right to 1400. Nothing in between and nothing over.
My ECM was starting to fail,,,found a good used one along with an injection pump from a cracked 53 block.
Swapped it out today and still the same.
Sort of seems like the APPs but my DRB3 reads the apps and it says it goes from 0 to 100 percent just fine.
Any ideas...
Thanks Chris
