Help stuck, failed steering gear and power steering pump
- Replies 25
- Views 8.8k
WiscoRedkneck 11 posts
Mopar1973Man 5 posts
Junkman 4 posts
dripley 2 posts
There are rebuild kits available for sealing the PS/Vac pumps. There are also vids on youtube. Peter Gould has some that go into detail. The drive cog can be replaced. I saw destructions in Peter'
Ok, so long short I'm at a friend's right now so certain things are limited.
What happened- hit a deer at 50 top of hill ran it over lost control hit a tree stump and broke the steering gear.
Limped it back to camp caught a ride into town got parts returned and replaced gear.
Bled system got it into town had it aligned, got cold hard steering at start up next day ran to store made it half way back when the truck started clunking from the power steering pump, pulled over and at idle the thing was shaking itself apart. Shut down towed back to friend's.
Now we tear the thing apart and find the power steering pump failed and took out the vacuum pump the vacuum pump sent small shiny crap into oil I think metal oil lab will get drained oil when I get home for inspection.
So where we are at now is we have a new vacuum and power steering pump we have been trying to align the vacuum pump with the power steering pump attached to the timing gear and this thing just won't seat.
We have destroyed two gaskets and are down to our third and final shot before I have to abandon the truck for a little while.
Whathave you guys found with past experience is the best way to align this thing?
