air filter
Hello will it hurt to delete air box just put air filter on inner fender. also opinions on spectre air filters with pre filter thanks.
  • Replies 31
  • Views 9.6k
    BHAF will last 100k miles without ever washing the filter. $50 bucks or so and cost way less than any other washable filter.    The other problem is what is the filtering micron rating of an
  • Marcus2000monster
    Marcus2000monster
    Another vote for Bhaf. Just pop the air box out and hook up a napa 6637 air filte to the stock turbo hose. Very simple yet effective.
  • Plus, oiled filters, you are sucking oil through your turbo and coating the impellers with gunk
I found that the Napa, Wix, Fleetguard and Cummins had the same size specifications.  The Baldwin and Hastings have almost identical web site lay outs and had the same specifications.
Quote
BHAF: NAPA FIL 2790, WIX 42790, Fleetguard AH19037, Hastings Af1012, and Baldwin PA2820
L          11.88”
OD      10.50”
ID         4.00”
Pre filter for above BHAF
FILTERWEARS F105K
BHAF: Napa FIL 6637, WIX 46637, Fleetguard AH1141, Hastings AF2329, Donaldson ECB085011, Baldwin PA2818 and Cummins 3912020
L          12.38”
OD        8.50”
ID        4.50”
FILTERWEARS K104k
Donaldson B105006
L          10.50”
OD      10.50”
ID          4.00”
ID 4.50" on the small one?
I run the 6637. It's a 4" ID. Fits right up. I'm not sure why this chart says 4.5"  unless the filter ID is 4.5". The neck s 4" on the last 2 I've owned.:shrug:
Thanks for the proof reading.  It's been corrected to  ID: 4.0"
Edited by IBMobile
3 hours ago, IBMobile said:
Fleetwear makes pre filters for both sizes.
Do you have a link for this? I'd like to have a pre filter for my 6637. I googled 'fleetwear' and don't get anything hat has to do with air filters.
@dripley
I figured it was a typo  ......:thumbup2:
I found them on Amazon in the automotive parts section.
FILTERWEAR pre filter F104K $24.95
FILTERWEAR pre filter F105K $29.95
Do you think you could put the 6637 on a tube that's 4 3/8 inch diameter? I have an afe box that I can just use, but is it flexible enough to fit over it?
No, It's stiff rubber with no give.
More like a semi-soft plastic of some sort. But its still very stiff material.
