- Replies 25
- Views 4.6k
beren 10 posts
Mopar1973Man 5 posts
Me78569 4 posts
Quadzilla Power 4 posts
Fun fact, if your ABS computer is programmed for aftermarket tire size, you need to leave the tire size as default or it won't be accurate.
The MPH correction only uses ABS speed and a tire size ratio to calculate the speed. We do use the tire size, speed, RPM, rear end ratio and transmission selected to calculate the gear and transm
Since I updated to 2.7 my engine speed has been off. It changes, but it's about 15mph higher than actual. It's not the app as I tried downgrading it and it made no difference. Around the same time I saw my fuel pressure was 16-18 where it had been 12-14 before. I thought maybe there had been a bad connection and plugging the plug back in showed a more true pressure reading. Today I was taking my son to daycare and it showed 60psi as my fuel pressure. That scared me a little so while driving I shut the engine off for a sec then keyed it back on (manual trans) and it started running again. The fuel pressure didn't change but I noticed my vehicle speed was correct this time, and stayed correct the rest of the trip. After I got to work I shut off the truck and turned the key to run without starting, the fuel pressure showed as 30, then 44 when I turned it on. Just now an hour later I did the same thing it read 4 & 18psi. Any ideas why it would read like this?
