- Replies 34
- Views 7k
Marcus2000monster 11 posts
AH64ID 7 posts
dripley 4 posts
Mopar1973Man 3 posts
TO much work and money for a 9% gear change. not a good ideal.
It will take tens of thousands of miles, or more, to offset the cost for just a mpg gain even if you do the work yourself. If you were to go from 14 to 16 mpg the CPM would be reduced by less the 0.03
Best way to quiet down a 2nd gen is to get a 3rd gen The VP trucks are the noisiest Cummins ever put in a Dodge.
I’m throwing around the idea of swapping 4:10s for 3:73s to grab lower rpms and higher mpgs. Anyone here ever done it? Is it something that could be done myself or need to be taken to a shop? At that ratio difference is a new carrier necessary? Easiest way seems to swap entire front and rear end but it’s hard to find someone near me with what I want lol.
