01 24v VP44 to VE Swap (info gathering)
- Replies 81
- Views 39.5k
Me78569 19 posts
Mopar1973Man 17 posts
LegendaryKing 17 posts
Nicarlov 7 posts
I've messed extensively with a VE 24V and the BEST the BEST I ever got hand calculated was 28mpg.........
A healthly VP44 is going to be more dynamic in use than a VE. the VE has variable timing, but it is advance as rpms increase. IE at 1200 rpm you get ~15* of timing but at 2500 rpm you get 22* of
I look forward to your results. PLEASE PLEASE PLEASE document your progress with it. Videos etc I am very curious to see the gains that could be had by using UDC vs the quadzilla. Snap
Truck:
2001 1 ton Quad Cab 4x4 6 speed HO 24v 5.9 VP44 140k miles
So far the only mod is a Diamond Eye 4” stainless exhaust
Philosophy of use:
Truck is to be a safe and reliable daily driver. Truck will also be used to tow a small camper short and long distances. Reliability, fuel economy, and towing capability with low EGT’s are more important than a large dyno number.
Goal:
Reliable 24v in the 400-500hp range (Number is less important than a good running truck).
Removal of the VP44 for a more reliable system. (non negotiable)
Possible recipe:
Fuel Boss lift pump
VE Fuel Pump w/ dynamic timing
Unknown Injector (TBD)
BHAF
HE351VE with Arduino (open to other turbo recommendations but like the idea of a fast spooling VNT that can perform on the top end as well)
Questions:
Does the VE swap require a cam gear and timing case like the PPump? Or is it just the VE gear and 1st gen cover? (Basically a pump swap)
I have yet to see this swap on an 01-02 truck. Are there any issues that I will see with this truck as opposed to older trucks? I read something about crank sensors?h
Will the 1st gen cover simply bolt onto the 01-02 trucks? No issues with harmonic balancer?
What are the differences in VE pumps? I see recommendations are all over the place. Intercooled? Non intercooled? 12mm? 14mm? Lift pump pressures? What is right for my truck? Why?
Will the HE351VE w/ Arduino supply enough air for the low EGT/safe power I’m looking to make?
What injector should I run with that turbo/fuel pump? What pop pressure should I run now that I’ll be running a VE pump instead of a VP? Why?
THANKS!
