- Replies 16
- Views 4.2k
puglyfe 6 posts
Mopar1973Man 4 posts
dripley 3 posts
Tractorman 1 post
Your scan tool/code reader/obd reader is defined wrong. That fault is for the ecm. Actually all the faults are related to the ecm failure.
ECM is fried first off. I would test for AC noise from the alternator. Then clear this code and see if it comes back. If it does the other codes are most likely from the AC noise of the alternator kil
Very much what happened to mine when the ECM committed suicide. I did not have the 606 code but it acted the same. From the 216 code you might have lost the vp too. Hard to say with the ECM flailing a
The truck is pitching a fit now. Was driving in stop and go traffic on the freeway last weekend. The temp started to rise a lot, then suddenly pegged. The CEL was on and then the check gauges light came on. Had noticed a bit of bucking and surging and the revs started to go high one time. Finally cleared traffic and then could not go over 1,500 rpm in any gear.
Read the code after getting home, this is what was listed:
P0606 PCM processor fault
P0238 Turbo boost sensor a ckt high input
P0123 Throttle position sensor signal voltage too high
P0118 Engine coolant temp sensor high
P0113 IAT sensor 1 Ckt temp high
P0216 Injector pump timing malfunction
P0121 Throttle position sensor signal voltage too low
Cleared the codes and the truck drove fine again. For about 25 miles. Then all of the codes came back. Cleared again and same thing.
So where to start to resolve the problem(s)? The truck is all stock except for exhaust. Has 155,000 miles on the clock now.
