Intermittent idle surge-increase
- Replies 79
- Views 19.9k
Red Rambler 38 posts
Mopar1973Man 14 posts
dripley 8 posts
Alexio Auditore 7 posts
Get the code reader and see what the codes are.
Yes codes first, but at idle with no TPS input ECM is in charge of that. Maybe cam sensor maybe something else, I would definitely check for excessive AC noise.
With temps at 20* it only takes 30 to 40 minutes to bring the block up to 60* for an easy start. No need for it to be on all night. I use a timer on mine.
Hey guys/gals. I have been having this issue that comes and goes, mostly under very low throttle or idling. The RPM’s will barley move up maybe 200 rpms very briefly. My fuel pressure stays steady at 17 PSI. The below video is what I am speaking of. As you can see, and this is the first time this has happened, the check engine light came on. My dad has a scanner I can plug in to read the code, however any ideas at what might be the possible issue. Thanks.
[video]
I also just noticed my temp gauge surges as well and then drops to zero after watching the video.
Edited by Red Rambler
