- Replies 16
- Views 2.6k
Don’t forget to flush the blinker fluid and to grease the muffler bearings.
@JAG1 you do realize this is all in fun blinker fluid and muffler bearings... The castor oil idea I would be afraid of adding oil to the coolant at all. The oil will most likely cause the
Why yes, from the same guy that told me I had to rotate the winter air in my tires and put summer air in. I don't know how it's going to help. There is a rubber seal keeping the coolan
Anyone heard of putting a bit castor oil in the coolant to help the water pump? Heard someone mentioning that at the autoparts store.
