- Replies 41
- Views 7.6k
Cummins_Crazy 10 posts
dripley 8 posts
notlimah 6 posts
trreed 4 posts
Popular Days
Yup they sure do! 2 stroke helps everything fuel touches
Like @notlimah mentioned they both of same design, kinda like politicians. " politicians are kind of like diapers and should be changed periodically and for the same reason"
I don't scientifically measure. I just guestimate how much to pour in. The biggest concern is the injection pump was designed for the old oily fuel, had greater lubrication, so adding 2 st
Need some help guys I have low fuel pressure on my airdog 150 it's running 13psi vp44 truck. The pump is kinda noisy I've checked power 13.82 volts checked my ground and changed the filters and relay and it's a new electric pump got a warranty about 2 months ago was fine then boom 13psi.
