7 pole trailer wiring
- Replies 9
- Views 2.2k
dripley 2 posts
01cummins4ever 2 posts
Unreal Summit 2 posts
Dieselfuture 1 post
Popular Days
I haven't seen both 4 pole and 7 pole set up from factory, just one or the other. If its a factory 7 pole, maybe someone spliced a 4 pole plug into it, I would resort back to all the factory wiring an
My 02 came stock with both. Part of the camper package I am thinking.
2002 2500 with I think factory tow package has both 4 pole and 7 hooks up. The 4 way works like it should. Turn signals and brakes. The 7 way only had turn signals and brake light brake box wouldn't come on either. Checked the 40 amp fuse under the hood for the trailer and it was bad swapped it out. Brake box worked and had running lights. Then the ground wire on the trailer was smoking and my third brake like was stuck on till we unhooked trailer. What is wired wrong on this truck? It ain't the trailer. I think something was odd about dodge wiring but I cant recall what. Any help is appreciated.
