I am gonna take the oil pan drain plug and throw it as far as I can...........
- Replies 13
- Views 3.1k
Mopar1973Man 3 posts
LiveOak 3 posts
dorkweed 2 posts
guesswho512 1 post
Got around to changing the oil and doing some services and maintenance on the wife's truck yesterday. It still has the OEM oil pan drain plug in it. I was going to replace the drain plug last time with a magnetic drain plug I bought from some scam artist on eBay but the plug didn't even come close to fitting. Last oil change I ordered a magnetic drain plug from Genos Garage and have it ready to install this time. http://www.genosgarage.com/prodinfo.asp?number=HDOP-KIT-22MM I put one of these drain plugs on my other truck and they work great. I just wish they would make them with the rare earth high strength magnets. I put these rare earth magnets on the oil filter as little extra measure of protection. Not sure if they make any difference or not but they are REALLY strong for such small magnets. I got them from Harbor Freight: http://www.harborfreight.com/10-piece-rare-earth-magnets-67488.html These magnets come in a stack of 10 but I place them 2 at a time stacked in a circle of 5 on the lower side of the oil filter. These puppies are unbelieveably strong for such a small magnet and for $1.99, the price is RIGHT!
As is par for the course, the OEM oil pan drain plug was a sombiatch to get loose (I torqued it to 37 ft./lbs. last oil change) and when I FINALLY did break it loose........of course oil comes spraying out the threads in a wide circle even though I only backed out the plug a 1/4 turn. Could not get the plug to come out without burning the hell out of my hands, so I had to wait until the oil flow slowed down a bit. I prefer to get the oil pan drain plug out right away so the oil can escape and drag as much if any crud along with it as possible. :banghead:
Maybe this drain plug might be put on duty as target on the 200 meter range.
Anyhow, I just needed to vent.
